Alembic - SF-2  [schematic]
Ferniff
Post by Ferniff »
mauman wrote: 16 Jun 2022, 05:04 I forgot to provide the bench-test frequency response of the clean (unfiltered) signal in the pedal adaptation. It's quite flat. With a 200 mV p-p input, relative to 1 kHz, with the Preamp level knob fully counterclockwise (gain = 1), the -1 dB points at the output are 13 Hz and 41.7 kHz. With the Preamp level knob fully clockwise (gain = 10), the -1 dB points are 14 Hz and 26.5 kHz.
To be clear, is the Q factor is what Alembic calls what would normally be called resonance on synths?
mauman
Has thanked: 101 times
Been thanked: 90 times
Post by mauman »
Welcome to the forum! Q factor is the ratio of the center frequency to the bandwidth. In a filter, if you narrow the bandwidth, you increase the Q and create a sharper and more audible "peak" in a bandpass filter or "valley" in a notch filter. Higher Q = higher resonance = lower damping. So yes, Q and resonance are related, and are inversely related to damping. In the SF-2, Alembic called their Q control "reciprocal damping ratio" which is just 2 x Q.
Jarno
my favorite amplifier: Something nice
Completed builds: Alembic-like state-variable and sallen-key filter preamps
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 18 times
Been thanked: 59 times
Post by Jarno »
This was under my radar :D
Pretty cool, nice work!
I made a dual filter preamp for my bassguitar, but I still need to verify the PCB (I couldn't get the first iteration to work, so I did a board spin, and also went for mostly SMT, still need to verify it). It uses the "CAMPUS" filter tone control (Alembic work-alike) times two, each pickup going into a separate filter, with a mixing stage at the end (I think 10 opamp stages in total, not sure how long the batteries will last..... :) ). I did not include a noise cancelling system with a dummy coil like on a series model Alembic.
mauman
Post by mauman »
I got a PM question about how to decrease the upper limit on the frequency range, which is currently 6kHz. Here's the process if you have a similar need, using Filter A as the example.
To halve the maximum center frequency from 6kHz to 3kHz, double the values of R7 & R8 from 755 ohms to 1.51k ohms. Or if you want a 4kHz upper limit, use a pair of 1.13k resistors for R7/R8. In either case, leave C2/C3 as they are (35.1 nF.)
R7/R8 set the maximum center frequency, and the pot value (100k) sets the minimum. The minimum of 45 Hz won't change more than 1 Hz when you change R7/R8. The formula for the center frequency is [1 divided by (2 * pi * R * C)] where R = [(F7 or F8) + the pot value] which depends on where the knob is set, and C = (C2 or C3). For the upper limit, let the pot be 0 ohms, and for the lower limit, let the pot be 100k ohms.
