Dunwich - Wizard Fuzz  [traced]
V1nce69
my favorite amplifier: Ampeg
Completed builds: Veroboards builds:
Throbak Overdrive Boost
Wampler Ecstasy
Creepy Fingers Doomidrive
Black Arts Quantum Mystic
Roger Mayer Voodoo Bass
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Fulltone 69 (GGG kit)
Russian Big Muff (Musikding kit)
EHX Bassballs (home etched using Topopiccione layout)
BJFE BBOD (home etched, thx FSB)
Triangle Muff (Guitar PCB board)
Deluxe Bass Fuzz (home etched,gausmarkov.net layout)
Clone Theory Chorus (Celeste pcb from lectric-fx)
Cornish G2 (home etch, layout thx FSB)
Shin-Ei FY-2 Ge version (home etched, own layout)
Klon (Aion Refractor pcb)
Mutron Phasor II (home etched, layout thx JohnK)
Sunny-T (pcb by guitar pcb)
Rocket Overdrive (pcb by Pepers' pedals)
Sonomatic Deluxe Tape Delay (pcb by Skidmark)
Black Arts Quantum Mystic (adapted storyboardist layout)
Has thanked: 36 times
Been thanked: 110 times
Post by V1nce69 »
Hi all,
Here are some pictures of my personal Dunwich Wizard Fuzz #85. As it's quite a rare and now unobtainium unit, I decided to trace it.
I carefully took it apart, unsoldered all components, measured the resistors with a multimeter, measured the transistors with Atlas DC55 and noted everything down.
Then I traced it using Illustrator and drew a schematic on Kicad. I made sure my schematic doesn't contain any error, as I redid the original pcb layout on Kicad.
P.S.: there was a small mistake in my tracing. Gain lug 1 should go to ground. I made the correction and updated the files
There you go:
outside view
outside view
gutshot
gutshot
pcb view top
pcb view top
depth pcb, left view
depth pcb, front view
depth pcb, right view
depth pcb, top view
depth pcb, top view
pcb bottom and pots
pcb bottom and pots
pcb bottom, close view
pcb top, cleaned
pcb top, cleaned
pcb bottom, cleaned
pcb bottom, cleaned
parts list
parts list
V1nce69
Wampler Ecstasy
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Post by V1nce69 »
I will gladly share the kicad files if someone is interested. I still need to create a project specific library for the symbols and footprints I used, so that it can be shared.
audioguy
Has thanked: 22 times
Been thanked: 7 times
Post by audioguy »
this looks amazing! I would love to build one, I've never used kicad but I could give it a go
V1nce69
Wampler Ecstasy
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Post by V1nce69 »
Here are my Kicad (version 5.1.9-0-10_14) files. I created a zip file in which are all documents you need in Kicad.
Just extract the zip file and put the extracted folder directly in your Kicad projects folder.
files corrected. Gain 1 now goes to ground, as it should
Dunwich Wizard Fuzz_KiCad files_corrected_20210519.zip
(228.42 KiB) Downloaded 224 times
audioguy
Post by audioguy »
awesome, thank you very much!!
V1nce69
Wampler Ecstasy
Idiot box Blowerbox
Hudson Sidecar
Pcb builds:
Post by V1nce69 »
I had a mistake in my schematic/tracing: lug 1 of gain pot should go to ground.
I corrected both the images in my first post and the docs in the zip file.
EmmG
Has thanked: 18 times
Been thanked: 46 times
Post by EmmG »
Vince, thanks for such a great tracing job! This is is a really heavy doom fuzz.
I built it using this vero layout:
dirtboxlayouts.blogspot.com/2021/05/dunwich-amplification-wizard-fuzz-big.html
https://dirtboxlayouts.blogspot.com/202 ... z-big.html
Alamondm
Post by Alamondm »
@vince69. Thank your time on this. I can verify your work. It works 100%. This is an awesome fuzz. Permanent home on my board.
cniers13
Post by cniers13 »
@vince69, would you be able to make a PCB for the dunwich da120? That would be awesome if you could!
vergadehule
Post by vergadehule »
I suppose that the bottom layer of the pcb is to ground.... Do you maybe know what's connected to the top layer ? Thanks
