PUP: a host of Perfectly Usable Phasers  [documentation]
Rodri_DiY
Post by Rodri_DiY »
Hey there! I've put together the pup 2 with a protoboard and it seems to work just fine, but I have a constant noise, like a mosquito's buzz, it seems to be the same frequency of the open E at 1st string.
Any thoughts about the issue? I've triple checked every componen and connection.
Thank!
Rodri_DiY
Post by Rodri_DiY »
Rodri_DiY wrote: 12 Mar 2023, 16:08 Hey there! I've put together the pup 2 with a protoboard and it seems to work just fine, but I have a constant noise, like a mosquito's buzz, it seems to be the same frequency of the open E at 1st string.
Thank!
Solved! Seems to be some ground loop. Just put an extra connection between board ground and a jack ground.
Rodri_DiY
Post by Rodri_DiY »
Hello! I've asambled the 4 stage version, it works great! but I have a problem, it makes a click like sound, always at the same rate as the pot sets. What can be causing this noise?
dylan159
my favorite amplifier: Chempion!
Completed builds: Oh boy...
Has thanked: 97 times
Been thanked: 536 times
Post by dylan159 »
Rodri_DiY wrote: 15 Mar 2023, 17:18 Hello! I've asambled the 4 stage version, it works great! but I have a problem, it makes a click like sound, always at the same rate as the pot sets. What can be causing this noise?
If it's faint, it's the lfo comparator coupling to the signal path. Try moving the rate pot wires or keep that stage away from the signal. The lfo in the trimless should be less susceptible because the edges are a bit more rounded
Personal blog/archive: https://bentfishbowl.wixsite.com/electronics
Find me at https://discord.gg/bMuhX4TkZM Audio Electronics discord server.
Rodri_DiY
Post by Rodri_DiY »
dylan159 wrote: 15 Mar 2023, 17:55 If it's faint, it's the lfo comparator coupling to the signal path. Try moving the rate pot wires or keep that stage away from the signal. The lfo in the trimless should be less susceptible because the edges are a bit more rounded
great! thanks! will do
Rodri_DiY
Post by Rodri_DiY »
Hi there! Sorry if I ask too many questions, I'm really into this project!
Do you think it's ok if I add a blend control like this? Is there a better way?: (PUP4)
Pot lug 1 to TL074 U3B 6
Pot lug 2 to TL074 input
Pot lug 3 to TL074 U1A 3
I've tried various B type pots, from 10k to 1M and don't know why, the 50k was by far the less noisy at 0% (no fx)
Thanks!!
dylan159
Post by dylan159 »
Rodri_DiY wrote: 16 Mar 2023, 01:43 Hi there! Sorry if I ask too many questions, I'm really into this project!
Thanks!!
No, that won't work well at all with an inverting amplifier. You should split the feed resistors and shunt them, something like the attached snippet, but ground is Vr.
Senza nome.png (2.28 KiB) Viewed 1068 times
Rodri_DiY
Post by Rodri_DiY »
dylan159 wrote: 16 Mar 2023, 09:52 No, that won't work well at all with an inverting amplifier. You should split the feed resistors and shunt them, something like the attached snippet, but ground is Vr.
Excelent! thanks! every ground is Vr in the snippet or just the pot one?
dylan159
Post by dylan159 »
Rodri_DiY wrote: 16 Mar 2023, 12:58
pot and +in. obviously not the output pulldown.
Rodri_DiY
Post by Rodri_DiY »
great! thanks, I supposed that.
So is this ok? in this diagram I should split into let's sayfor example two 4.7k resistors each R33 and R34?
dylan159
Post by dylan159 »
Rodri_DiY wrote: 16 Mar 2023, 17:58 great! thanks, I supposed that.
It depends on the pot you're going to use and how you want to taper the control. You can mess with the attached spreadsheet.
1KnobBlend.ods
(31.87 KiB) Downloaded 67 times
Rodri_DiY
Post by Rodri_DiY »
dylan159 wrote: 19 Mar 2023, 15:21 It depends on the pot you're going to use and how you want to taper the control. You can mess with the attached spreadsheet.
Thanks you so much!
t1redhands
Post by t1redhands »
If I wanted to add a depth pot to the LFO, would it be as simple as adding a pot to ground right before R11? Kind of like the depth knob for the CE-2?
dylan159
Post by dylan159 »
t1redhands wrote: 09 Sep 2023, 21:50 If I wanted to add a depth pot to the LFO, would it be as simple as adding a pot to ground right before R11? Kind of like the depth knob for the CE-2?
I'm assuming you mean the PUP 4 with the trim them. That is the most straightforward to add depth to. Not ground anyway, but a to a mid-supply reference which isn't the main one. You might get away with using the same one as rate without too much asymmetry, or make another similar one. If this voltage isn't half supply you can make it drift higher or lower while you attenuate it, to your advantage.
t1redhands
dylan159 wrote: 10 Sep 2023, 00:15
Excellent, that makes sense, thanks!
