Union Tube & Transistor Tourbender  [traced]
Nocentelli
Has thanked: 1152 times
Been thanked: 954 times
Post by Nocentelli »
Another excellent teardown...
Has thanked: 183 times
Been thanked: 468 times
I understand why he used the huge filter capacitors, but they're not necessary. A different power arrangement would allow him to do it with smaller values and possibly have better results. The Dunlop Fuzz Face from late 90's/early 00's did a similar thing with large filter caps. The ZVex Fuzz Factory is what happens when you DON'T use large filter caps (or any at all).
Would probably be smart if they moved the polarity reversal protection diode to before the first filter cap, so that cap would be protected too. I've seen them get damaged from reverse polarity before.
graybench
Has thanked: 18 times
Been thanked: 132 times
Post by graybench »
Oh hi, uh... you know sometimes I forget to post here. Dang, sorry you had to redraw the schem Nocentelli.
Here are the trace pictures:
The 10n cap to ground is on the input jack side of the 4.7u. I'll post my schematic for simplicity:
schem1.pdf
(15.28 KiB) Downloaded 109 times
