BAJA Ampeg SVT bass amplifier pedal 9v 010418 [documentation]
- bajaman
- Has thanked: 596 times
- Been thanked: 2061 times
Hello Tuck
yes - exactly like the Ampeg
You could always remove the input jfet buffer and connect the input socket directly to the normal/bright switch - in this case you would have to scale up the resistor values x10 (100k, 47k, and 5M6) and decrease the capacitor value x10 (220p) - then it will be exactly the same input impedance as the Ampeg SVT
- Tassieviking
What sort of 12v supply are you using ?
It could be your 12v supply that is causing the noise, especially if it is plugged into a power point.
- Paul_5
Looking at the schematic there's very little else to go wrong. Check your voltages at the IC pins.
The sounds in my head don't match the sounds from my amp, I guess that's why I'm here...
I'm way out of my depth here, but I'm reading some mismatches of 50-150 mV on most of the + and - input voltage pin pairs, which, if I understand correctly, is often a sign that something is wrong. I'll just replace them, use sockets this time, and hope for the best.
OK, this pedal is every bassist's dream. It makes any amp sound great. I went to a studio the other day, where the amp was crap, but with this pedal, it was night and day.
Would I want to produce it for commercial purposes (at this point, just an idea), how would I need to license your work?
Pedro Cucaracha
(Easy, cheap and dirty)
- bajaman
Hello Pedro
No need to license it but a mention of it being a design published on freestompboxes.org would be a nice gesture - glad you like it
cheers bajaman
cheers bajaman
Excellent! if I move ahead with this initiative, I'll make sure to provide the credits. Thanks a lot!
Pedro Cucaracha
- Paul_5
What’s the best way to boost the output on this? Would I be ok using the last opamp stage as a boost instead of a buffer?
Here's a test of the SVT, compared to a clone of the Sansamp VT Bass.
Treble caps and pot were updated to the Rev1 specs, but I didn't decrease the bass pot.
Sansamp VT clone? Schematic?NazarDaniel wrote: ↑13 Dec 2023, 15:50 Here's a test of the SVT, compared to a clone of the Sansamp VT Bass.
- Tassieviking
I personally would also write "Design By Bajaman" on the PCB and also include it on any instructions you make up.
I think we all should honor the designer if we make up PCB's of someone else's design, especially Steves great pedal designs that have been made available for everyone to use.
Credit where credit is due is my philosophy.
Thanks BAJA
- tedsorvino
Hi everyone.
Before start building the pedal.
i would like to know if it’s ok to use either j109 or j112 instead of the 2sk170 jfet (for buffer use).
Thanks in advance
Thanks in advance
- my favorite amplifier: Fender Twin Reverb
- Completed builds: Vox Ac15, Fender (different models), Preamplifiers, MIxers, Power stages, etc
Good morning, first of all I introduce myself, I am new to this forum although not to electronic circuits, which I have been in for several years. I have built this circuit but I have a very big distortion and very little gain in the final stage. Have any of you examined this circuit on an oscilloscope? The signal in the last stage is really very distorted. I have simulated the circuit in Proteus but It is not very reliable. Thank you and regards
