VFE Windbag (delay/reverb) - volume drop/muffed sound when engaged
Bobb_Lobblaw
Post by Bobb_Lobblaw »
Hello,
I'm building a VFE Windbag and I'm having an issue.
Everything seems to be working fine, but I get a steep volume drop and a muffled under-the-blanket sound when engaged. If I crank the volume, I can hear everything doing what it's supposed to do delay, reverb, envelope, etc...just at a very low and muffled volume like a hi pass filter.
I checked the voltages, and they are a bit off, but I'm not sure what to do about that. If it matters, I subbed a TL072 for the OPA2134 and I subbed a TC1044SCPA for the TC7662B. Oh, and my DM doesn't have an mV setting.
Any help is greatly appreciated.
https://www.madbeanpedals.com/projects/_folders/VFE/pdf/Windbag.pdf
Thanks.
Bobb_Lobblaw
Hello,
I'll try again...
I'm having an issue with the Windbag. https://www.madbeanpedals.com/projects/ ... indbag.pdf.
Tracing the audio signal it hits the relay which then sends to R1. The signal going in to R1 is strong..coming out the other leg it's severely dropped and muffled. I reflowed R1, I switched R1 out for another 220K and the same vol. drop/muffle happens.
If I crank the sound, I can hear everything doing what it's supposed to do delay, reverb, envelope, etc...just at a very low and muffled volume.
x-tn
Has thanked: 212 times
Been thanked: 35 times
Post by x-tn »
Bobb_Lobblaw wrote: 22 May 2023, 01:42 The signal going in to R1 is strong..coming out the other leg it's severely dropped and muffled. I reflowed R1, I switched R1 out for another 220K and the same vol. drop/muffle happens.
IC1 may be faulty. Try another TL072 or a similar dual op-amp.
Also measure R24 (10 Megaohms).
Bobb_Lobblaw
Thanks for the reply!
Staring forlornly at the schematic, I think R1 is actually supposed to drop the volume of the signal on its way into the op-amp (I've tried a couple of different TL072s with no change), and then into PT2399...But it never gets re-amplified and it's just too muffled.
So, I socketed R1 and tried several resistor values lower than the original 220K, and I can get the volume up to a usable level. But I can't seem to clean up the muffled audio signal. It's like cranked a low-pass filter sound..
Could I possible wire a tone pot somewhere?
Thanks,
