I am selling gear fir my recently widowed friend. The music room has the usual number of guitars amps petals etc. But the one that is stuck is the ibanez ue400 box.
There is no footcontroller that I can see and I want to try a test the ue400 is working OK.
Any ideas suggestions easy workarounds to test box without the footcontroller?
Ibanez ue400 foot controller
- lolbou
The original plug pins diameter is 1.5mm. If you find a suitable copper wire, you can easily jumper the pins for test purpose...
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
