Mooer - Grey Faze / Tomsline - G-fuzz
Bernardduur
Has thanked: 89 times
Been thanked: 665 times
Post by Bernardduur »
I got this pedal and LOVE it!!
Great fuzz face-ish sounds with two 2N404 transistors
For pics check my Blog / Instagram
Follow my love for pedals and amps on https://bernardduur.blogspot.com and https://www.instagram.com/bernardduur3
Has thanked: 1636 times
Been thanked: 1336 times
Post by Manfred »
Thanks for sharing.
Can you please measure the following voltage values.
At the base of Q1.
At the emitter of Q2
At the connection point between R4 and R7.
Ichabod_Crane
Has thanked: 73 times
Been thanked: 35 times
Post by Ichabod_Crane »
All that power supply circuit, the 1044... to get 7.0v?
FiveseveN
Has thanked: 205 times
Been thanked: 112 times
Post by FiveseveN »
MINUS 7V, so one can use the PNP setup without all the "positive ground" caveats.
Ichabod_Crane
Thanks.
And is FB2 ferrite? Is that what drop the voltage?
mauman
Has thanked: 333 times
Been thanked: 156 times
Post by mauman »
R3 (100R) and R2 (1k) make a voltage divider for the -V DC bus. If the pin 5 output of the 1044 charge pump is around -8V, this divider would drop it to around -7.2V. A ferrite bead's typical DC resistance is less than 1 ohm, so FB2 doesn't have much effect on DC voltage, it's meant to help filter AC noise.
Bernardduur
Manfred wrote: 04 Nov 2023, 09:28 Thanks for sharing.
At the base of Q1.
I'll measure it tonight
Bernardduur
All measurements in the case and with all controls to full
Post by Manfred »
Hi Bernardduur.
thanks for reading the voltage values. :thumbsup
dmc777
Been thanked: 8 times
Post by dmc777 »
That’s nice to know. Kinda sounds like a toss up as to whether you’re going to get one biased correctly though. How do they sound compared to a Tonebender MK1.5? I still use my old Smitty Pedals “Smitty Bender” mk1.5 with OC75s. I’ll never sell it but I do need a new fuzz face.
