Bogner - Harlow Compressor (gut shots)  [traced]
mr coffee
Has thanked: 74 times
Been thanked: 14 times
Post by mr coffee »
Anybody looked under the hood to see what compressor VGA\VCA this thing is using? And where they put Rupert's littlr tranny in the circuit? And what kind of EQ they're using before and after the Tranny?
mr coffee
okgb
Has thanked: 225 times
Been thanked: 38 times
Post by okgb »
I'd be curious to see any of the other pedals as well , did they just slap the same xfmr on the output
of every pedal, seemed like a good idea for hype if nothing else
liquidfunkateer
Been thanked: 18 times
Post by liquidfunkateer »
Love it, so much that I want a second one :P
Any advice for safe degooping?
liquidfunkateer
V1 one here.
viewtopic.php?t=31756
I want to clean the goop. No experience, any advice?
liquidfunkateer
Episode 2.
Hot air gun
Low setting 350° C
Heat applied intermitently from 20 to 25 cm
Scratching with a small cutter and a small screwdriver
it worked fine for a first time degooping.
liquidfunkateer
R.I.P. R109, rest in the goop
R116 isn't readable, I'll measure it along with the rest
Three bipolar caps - Two Nichicon ES, 10µF 50v - One UKW, 100µF 35v
The two ICs, U102 and U103 are TL072CP that loose cable connects PIN4 of each ICs
liquidfunkateer
All right, degooping completed, part 2 here.
I'd be curious to see the Bogner Lyndhurst as well.
Lithium_Grim
Has thanked: 38 times
Been thanked: 58 times
Post by Lithium_Grim »
Looking at the trannies on the main board now. They are marked 12x or i2x. Does anyone know what type of trannies those are?
I only give negativ feedback and y'all love it!
PCB shop
szukalski
Has thanked: 35 times
Been thanked: 12 times
Post by szukalski »
2X is a 4401 I think.
Lithium_Grim
I received the board from liquidfunkateer (alex) and am tracing it as we speak. Here is a first schematic sketch of the degooped part:
<removed due to alterations>
In purple the designations as found on the degooped PCB and the now desoldered pcb:
Questions:
1. Can anyone spot any obviuous errors?
2. I am wondering what kind of JFEt is used. Any ideas (measurements are in the picture)?
3. C9 (C115) looks weird in the polarity, however i measured it multiple times to verify it.[/list]
PCB shop
Has thanked: 4380 times
Been thanked: 2126 times
liquidfunkateer has been promoted to the honory rank of Degoop Doctor
If I missed anybody else who hacked into a gooped, untraced pedal, please contact me in pm.
Thanks so much for your contributions liquidfunkateer!
Lithium_Grim
And a small update:
PCB shop
Lithium_Grim
Any ideas on the JFET?
Q1 measured @ DCA75 as N-Ch JFET symmetrical Source/Drain
Vgs[off[=-1,64V @ Id=4,8uA
Vgs[on]=0,32V @ Id=5,00mA
gfs=4,0mA/V@ Id=3,0mA to 5,0mA
Idss=3,67mA @ Vds=3,00V
Rds[on]=270,6 Ohm @ Id=5,0mA and Vgs=0,0V
PCB shop
Lithium_Grim
Ok here is the full version. Still not 100% verified, but I did multiple runs on all traces.
I am still looking for input on the transistors. The Hfe of the BJT (U2/U3) seems to be higher than the MMBT4401. Any suggestions?
I am also still looking for suggestions on the JFET. Anyone?
Lastly, I'll try to find a variac and determine the ratios on the Neve transformer. To be continued!
PCB shop
Lithium_Grim
And some more info on the trannies:
PCB shop
Has thanked: 591 times
Been thanked: 2037 times
wow - excellent work here
my guess is that the fet is a BF245A smd equivalent (https://www.onsemi.com/pdf/datasheet/bf245a-d.pdf)
The vgs and idss fall into line with this device and it was the jfet used in the classic Urei 1176 studio compressor
I would think any small signal NPN transistors with a reasonable hfe would work here.
Cheers
Lithium_Grim
bajaman wrote: 12 Feb 2024, 22:57 my guess is that the fet is a BF245A smd equivalent (https://www.onsemi.com/pdf/datasheet/bf245a-d.pdf)
Thanks bajaman! Since the BJT is a SMD, what equivalent BJT would you suggest? MMBT5088 (the savior of the universe)?
Dito for the FET. It is a SMD version with no readable markings. Any equivalent suggestion to the BF245A? 2N4416 MMBF5457?
I got my idea from here https://www.utmel.com/components/bf245- ... eet?id=493
PCB shop
The bjt transistors are most likely MMBT4401 type and the jfet MMBF5457
Lithium_Grim
PCB shop
Lithium_Grim
And here is the adjusted schematic.
Anyone see any obvious mistakes or points of further investigation?
PCB shop
