TC Electronic XII Phaser replacement ICs
Stevenrb718
Post by Stevenrb718 »
Anybody know of a pin-equivalent replacement for the IC1 in the vintage version of this pedal? 1, 2, & 3 have the numbers scraped, but I believe them to be RC4149s based on random schematics. According to the schematic, it could also be an XR4212 but based on anything I've found that's a 14 pin IC. The one in the pedal I have is 16.
Jarno
my favorite amplifier: Something nice
Completed builds: Alembic-like state-variable and sallen-key filter preamps
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 27 times
Been thanked: 81 times
Post by Jarno »
Was that the quad opamp with off-standard pinout? IIRC it was old but you could do a modern opamp on an adapter board to change the pinout (if there's room for it).
Maybe a place like the electronic goldmine still has them?
Stevenrb718
Jarno wrote: 02 Apr 2024, 07:31 Was that the quad opamp with off-standard pinout? IIRC it was old but you could do a modern opamp on an adapter board to change the pinout (if there's room for it).
I can't find any NOS or pulled ICs anywhere. I still haven't found a proper datasheet to find an equivalent or replacement IC.
Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
So many things! :D
Post by Jarno »
If it is a quad opamp, it might be the same pinout as rc4136, you might try and that looks plausible from tracing part of the pcb, for instance power supply connections, they go to the end if it's a similar pinout, and to the middle if it's the modern pinout.
Tzolov
Post by Tzolov »
Desolder the chip and look under it both on pcb marking and also the IC , XR were marking chips on the underside too.
