EHX Bad Stone Phase Shifter EH5850 V1 'Mummy Face' Traced  [schematic]
TWSpedals
Has thanked: 22 times
Been thanked: 55 times
Post by TWSpedals »
Crazy this doesn't seem to have been traced before.
I was compelled to trace this unit as the only available schematic (a factory one at that) didn't match what I had infront of me.
Noticed differences between factory schematic and my trace:
•There's numerous resistor value differences
•A whole output buffer added
•No resistor between ground and the + input on the final all-pass stage.
•The colour switch and blend labelled the right way.
•No input 'pulldown' resistor.
Quad op-amps have been sanded.
Jfets have no identifiers other than 'SCOTT'
Power section, last all-pass filter, LFO
95% of signal path
95% of signal path
Have a nice day!
uncleboko
Has thanked: 58 times
Been thanked: 42 times
Post by uncleboko »
I think from memory the FETs were 2N4302, but I'm sure I made one using 2N3819!
audiohub
Post by audiohub »
My roommate had one of these back in the mid 70's, and we traced it back then. Your trace looks pretty much like I remember it from way back then.
We figured out that the opamps were probably LM324s, which had an application note for those 27k resistors tied to -9 volts on the outputs (plus, we were actually able to still read the number on one of the packages).
It was a pretty good sounding phaser, as I remember.
"I want to GO to there..."
george giblet
Has thanked: 212 times
Been thanked: 314 times
Post by george giblet »
TWSpedals wrote: 21 Apr 2024, 19:18 Crazy this doesn't seem to have been traced before.
Good work. It's amazing what you find when you do a trace of some pedals. Plenty of cases where schematics having been kicking around for years and have been wrong, or, there's more than one version.
(I thought I had a schematic for a JFET based EHX Phaser. I looked through one of my archives and couldn't find it. It may be in a later archive but those aren't easy to get to ATM.)
fanheritage
Post by fanheritage »
uncleboko wrote: 21 Apr 2024, 20:53 I think from memory the FETs were 2N4302, but I'm sure I made one using 2N3819!dinosaur game
Will it give the same results?
uncleboko
Post by uncleboko »
fanheritage wrote: 13 May 2024, 02:16
That I can't remember - 40 years or so ago!
