Fishman Universal Rechargeable Battery Pack
Greetings! Been looking for pictures of this thing with no luck. Was wondering if anyone would mind taking pictures of one of these? Thank you!
- Jarno
- my favorite amplifier: Something nice
- Completed builds: Alembic-like state-variable and sallen-key filter preamps
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D - Location: Rosmalen, NL
- Has thanked: 30 times
- Been thanked: 85 times
Ben Crowe from Crimson Guitars posted a video on youtube where he takes a apart a Fender Acoustasonic, which has Fishman Electronics and the batterypack.
Thanks for the video! I checked it out but wasn’t able to get a good look at the PCB…
I’m hoping someone here has one and wouldn’t mind sharing some pictures of the front and back. I found a picture here: https://khronscave.blogspot.com/2019/09 ... h.html?m=1, but, unfortunately, is not head on and there’s no pictures of the back.
Hey! It’s been a while. Just wanted to let you all know that I was able to trace it and am working on a PCB. I am however missing a resistor value.
I’m reaching out to @Voffkins for help, however, if anybody has a unit, would you mind measuring that resistor for me? It’s R11 on the back. Thanks!
I’ll keep you all posted.
I'm sorry but right now I don't have this bass, I'm a luthier and I had this instrument to adjust, when a client brings it to me again I'll look at itABtheBassPlayer wrote: ↑06 Sep 2024, 23:55 Hey! It’s been a while. Just wanted to let you all know that I was able to trace it and am working on a PCB. I am however missing a resistor value.
- Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
I think it is risky to just go by a trace, unless this is just a way of understanding what is going on. Don't assume you can just roll a PCB and expect it to work. This is a rechargeable battery, and as such it needs charging circuitry as specified by the battery supplier.
If there is some on/off circuitry, it is probably also better to design that around the functionality you want.
These batteries can go "Bang!" and cause a fire, proceed with caution.
No worries! I've been reading a lot into lithium batteries and battery charging. I've been working on this for quite a while now and am confident in my trace. I also used the datasheets to confirm my trace.Jarno wrote: ↑09 Sep 2024, 12:20 I think it is risky to just go by a trace, unless this is just a way of understanding what is going on. Don't assume you can just roll a PCB and expect it to work. This is a rechargeable battery, and as such it needs charging circuitry as specified by the battery supplier.
I finished my PCB and have it on order. Since I'm using a different charger, I had to add a few extra bits.
- Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
Very cool!
Did look at these, can you share a schematic of how you did this (would love a 18V variant, as that is what I typically use for onboard electronics (on electric basses))?
- plush
You can use mine as an example.
It's a replacement for a fender acoustasonic charger/boost module which i've designed and built from scratch.
I’ll post the schematic after I verify it.
Just like in @plush’s schematic, you have to change the feedback resistors in order to set the output voltage.
R1 is 1.43M Ohm
R2 would then be 105k Ohm
Quick update, PCBs and parts are still in transit. I hope it’ll just be another week or so… Waiting impatiently
- Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
Very very cool!
Hey! Parts came in this morning. The PCBs will be here on Tuesday.
Greetings! I was able to put some together. Here they are, cleaned up and tested. Everything came out okay.
- Jarno
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Tables
Bookshelves
Basses
Looks great, hopefully nothing explodes
In any case do keep safety in mind!
Greetings!
Here is the schematic as promised. Please note, instead of the MAX8895X, I opted to use the popular TP4056 and incorporated load sharing. Please see attached.
