Hey everyone,
I wasn't sure if I should have posted in the old Hudson sidecar thread.
In 2024 Hudson Electronics introduced the "Motorcycle" as a limited edition:
"The Motorcycle is a modified version of our Sidecar overdrive pedal – our take on the soft clipping overdrive circuit with the added versatility of a powerful two band EQ which draws inspiration from a vintage recording console."
I have built many pedals, but I have never drawn a schematic before. I did my best to identify all the parts and the differences between the sidecar and motorcycle. Would someone be willing to help me draw a schematic and vero board?
This is what I found out so far:
All resistors are the same, he changed the 68n cap to a 33n.
The gain and clipping section are completely different:
IC: OPA2134PA instead of LM4562 (not a big difference as both are hifi opamps)
Q1 (big change): Germanium Transistor instead of a BC549C
D1: LED for both
D2: looks like a 4005 instead of a 4148 (got that from the fulldrive I guess)
D3: nothing (Germanium Diode before)
Instead he uses the TY-250p for clipping.
Also he changed some pot values.
For more details and gutshots see the attachments.
Here the sidecar gutshots as a comparison:
I think all the changes fit with its marketing description:
"The Motorcycle has been tuned to give more distortion in the lower frequencies and the EQ a different response. It also adds a transformer at the end of the signal chain to soften the attack and generate a subtle layer of saturation to the signal."
What can you make of this?
Hudson Electronics Motorcycle
- Completed builds: Overdrive
Tube Screamer 808
Klon Centaur
Way Huge Red Llama (Dual Llama)
King of Tone
Way Huge Geisha Drive
EQD Crimson Drive
Hudson Broadcast
Les Lius
Catalinbread RAH Deluxe (Catalinbread Naga Viper + RAH)
Distortion
MXR Distortion+
1981 DRV
Fuzz
Triangle Big Muff
Green Russian Big Muff
Ibanez Standard Fuzz
Tone Bender MKII
Classic 108 Fuzz (Silicon Fuzz Face with Buffer)
Harmonic Percolator
Fuzzrite
D*A*M Buzzotron (Clone of Burns Buzzaround)
Reverb
Death by Audio Reverberation Machine
Modulation
Phase 90
MXR Dyncomp
Boss Chorus CE-2 - Has thanked: 2 times
Hudson Sidecar vs Motorcycle.pdf
- Hudson Sidecar vs Motorcycle: Differences
- (401.46 KiB) Downloaded 90 times
