ProAnalog Dual Drive Mk1
TWSpedals
Has thanked: 22 times
Been thanked: 69 times
Post by TWSpedals »
Traced from a 2004 unit.
Clearly based on a tube screamer with some interesting addtions/changes. With my set up the Phat switch doesn't do much.
There is no pull down resistors. The Bias rail isn't at half the supply. The last half of the 2nd op-amp is not used.
I can't add the schematic so here is a link to my reddit post with it attached. https://www.reddit.com/r/diypedals/comm ... drive_mk1/
Have a nice day!
karul
Has thanked: 668 times
Been thanked: 291 times
Post by karul »
Sure you can upload images. Here it is.
TWSpedals
Post by TWSpedals »
Honestly I tried over and over on different sized jpegs and upload sources but it kept saying it was too large. Anyway, thank you for adding it here.
Have a nice day!
karul
Post by karul »
TWSpedals wrote: 13 Feb 2025, 10:36 Honestly I tried over and over on different sized jpegs and upload sources but it kept saying it was too large. Anyway, thank you for adding it here.
I don't know the exact max file size and resolution limit for images on this forum, but when I get a message that it's too big, I use some compression. Lately I use webp format for smallest possible file size.
Jarno
my favorite amplifier: Something nice
Completed builds: Alembic-like state-variable and sallen-key filter preamps
Lovepedal Eternity
Phase 100
Brown source
Fuzz Face
Flipster
Alembic F2B (tube preamp)
Opamp and FET buffers
Tables
Bookshelves
Basses
So many things! :D
Has thanked: 34 times
Been thanked: 87 times
Post by Jarno »
Seems like a waste of nice germanium transistors, but maybe one can use components from the "scratch-n-dent" bin (so low HFE, more leakage than preferable etc.)
TWSpedals
Post by TWSpedals »
Jarno wrote: 13 Feb 2025, 14:49 Seems like a waste of nice germanium transistors, but maybe one can use components from the "scratch-n-dent" bin (so low HFE, more leakage than preferable etc.)
Assuming my schematic is accurate (I believe it is) I agree the germanium transistors as diodes is a shame. A lot could be DC coupled as the 1uf capacitors seem a little redundant. The whole half of a 4558 not being used when there's a transistor used as an output buffer is another interesting choice.
Have a nice day!
TWSpedals
Post by TWSpedals »
Actually it's pretty much an exact come of an Ibanez Super Tube with a few mods.
Have a nice day!
