Piggyback Si transistors to simulate Ger ???
Postby gght » 18 Jun 2008, 00:15
Say a thread about this on DIY and a mention of it here by Modman. Was just wondering:
How did they sound?? Just like Ger, or so-so??
gght
Have thanks: 9 times
Re: Piggyback Si transistors to simulate Ger ???
Postby Greg » 18 Jun 2008, 01:08
I think the aim of the piggy backing is to reduce Hfe isn't it.
If you're looking for the softer response of a Germanium, a cap across the legs can help.
Greg
Has thanked: 77 times
Have thanks: 195 times
Postby puppiesonacid » 18 Jun 2008, 01:13
Greg_G wrote:I think the aim of the piggy backing is to reduce Hfe isn't it.
which legs?
puppiesonacid
Have thanks: 5 times
Postby Greg » 18 Jun 2008, 01:42
which legs?
Collector to Base... something around 50 to 100pf works well.
Greg
Postby gght » 18 Jun 2008, 01:46
From what I got, it was a method of imitating Ger. transistors with Si transistors, I thought sounded interesting, as I am going to build a FF type clone. Seems the idea died down.
Quoting modman's post here:
Postby modman on Thu Nov 01, 2007 3:29 am
sosodef wrote:I wonder could that range control work on a fet based boost?
Anyone find any success with silicone in the rangemaster?
My dad always told me and again last week: just act normal. But I can't. I was going to build a nice GE FUzz and GE Rangemaster to check out the mojo. Couldn't stick to that plan anymore once I read Brett's Piggybacking thread at diystbxes. I built a piggyback Fuzz and a piggyback Rangemaster
I couldn't believe that he thread died out on a 'oh we found some low gain si so we stopped experimenting.' This was the ticket to building a fuzz almost two random couples of cheapo transistors. Strange boutiquers haven't picked this up yet...
1. Take two identical random silicon transistors (for more mojo: your fav fuzz silicons
2. Tie the BASES together,
3. Cut off one COLLECTOR
4. connect a 3k to 6k resistor between the EMITTER of the collectorless devicr and the EMITTER of the other transistor.
By varying the resistance, you can dial in the gain you want...
Read more here:
http://www.diystompboxes.com/smfforum/i ... ic=49543.0
or try Brett suggestion of low gain SI for your Rangemaster?
Quote from: brett on 20-09-2006, 05:27:28
After word got out about the qualities of the 2N2369A (hFE about 70), I mostly lost interest.
allow me to quote from the above thread. Maybe I should do some clips with my piggybacked Rangemaster tomorrow....
RG wrote:« Reply #7 on: 20-09-2006, 22:30:54 »
It's only a suspicion, but I'll bet that the gain reduction does not remain constant across a range of values of base current.
Since the active base has an effective Shockley resistance and the passive one does not, it would be moderately amazing if the gain reduction was linear.
This is probably a Good Thing, in that it is even more asymmetrical than a transistor all by itself. It may be more Fuzz Face-y than a realy germanium FF.
It's worth some more testing.
gght
Postby gght » 18 Jun 2008, 01:50
Greg, how does the sound (using the cap on the legs) compare to a real Ger. tranny??
gght
Postby Greg » 18 Jun 2008, 02:15
gght wrote:Greg, how does the sound (using the cap on the legs) compare to a real Ger. tranny??
It takes a little of the biting sharp edge of a Si away...
Closer to the sound of a Germanium, but not exactly the same in feel, etc.
In a band situation you probably wouldn't pick the difference, but side by side on their own you would. Lots of people like the silicon for it's bite of course... I love a good Germanium FF, but they don't always sound good or cut through well in a band, especially if you don't cut the Bass a bit.
Greg
Postby puppiesonacid » 18 Jun 2008, 15:05
Code: Select all
this is very intresting... i like the experiemental nature of this
puppiesonacid
Postby Emanuele » 26 Jun 2008, 11:20
:hmmm: *starts to work on some ideas*
Emanuele
Postby modman » 26 Jun 2008, 11:45
here I think was the original thread on
Relative importance of Gain in a Fuzz Face
for anybody who missed it.
Please, support freestompboxes.org on Patreon for just 1 pcb per year!
Has thanked: 3397 times
Have thanks: 640 times
Postby Redhouse » 31 Aug 2008, 17:53
It was Bret's work originally, and it was to get a proper FF Hfe range from silicon, the resistor across the Emitters was originally small but was found to work best with values in the range of 2K-200K or so depending on your two Transistors and the Hfe you are trying to dial-in.
How does it sound? ...IMHO with the right resistor it sounds much better than Ge's, stays tight in the low end where Ge's start to mush-out, much less noise (hiss) and you get away from that temperature problem the Ge's have.
To find the right resistor for your two transistors temporarily install a 200k trimmer where the resistor goes, plug in your unit and play a playing volume (not bedroom levels) and dial in the trimmer untill you arrive at where you bet the best sound, remove the trimmers and install resistors.
I still have a small stash of AC128 and AC125 I got from a guy in the UK a few years ago (not selling any) I save for Ge builds that "must have" them, but IMHO the Bret-Piggyback thing sounds way better.
Here is a pic of a board I made for dialing-in piggyback's and the other FF parameters, it has trimmers and switchable caps to dial in things just right for a client/customer, sure it takes a little time to build a board like this BUT you never have to go back parts-swapping on finished boards to find a sweet spot for someone.
(the stuff in the lower left corner is for power)
Redhouse
Postby R.G. » 31 Aug 2008, 21:27
Redhouse wrote:It was Bret's work originally, and it was to get a proper FF Hfe range from silicon, the resistor across the Emitters was originally small but was found to work best with values in the range of 2K-200K or so depending on your two Transistors and the Hfe you are trying to dial-in.
Actually, I came up with piggybacking. I initially speculated that it would cut the effective gain of the active transistor in half. It turned out to reduce it much more than half, because the piggybacking transistor was working at such a low current level.
Brett did the work on the resistor between emitters to tailor the effective gain.
It's all there in the forum archives.
R.G.
Have thanks: 41 times
Postby condorface » 12 Oct 2009, 15:55
How Identical do the two transistors have to be for piggybacking? Do you just need the same name transistors, or do you need to test them to find exact matches?
condorface
Postby HydrozeenElectronics » 13 Oct 2009, 06:40
condorface wrote:How Identical do the two transistors have to be for piggybacking? Do you just need the same name transistors, or do you need to test them to find exact matches?
Just the same type. I tried it with some 2n0588 and it sounded pretty good. give it a shot and see what you think.
Postby condorface » 13 Oct 2009, 12:54
Thanks. I plan on actually doing this up right on the breadboard first to dial in the gains before soldering the resistor. I've got an old broken bogen PA with 2n5089s that I plan to salvage parts from. Not too mention tropical caps.... 8)
condorface
Postby HydrozeenElectronics » 13 Oct 2009, 23:01
A little trim pot works great that way you can strum with one hand and adjust with the other to dial in the best tone.
Postby grrrunge » 02 Jun 2012, 12:06
I am insanely interested in this project. I like the overall sound of GE fuzzes, but i absolutely hate sloppy low end.
I want crushing palm mutes at all time, so "flart-flart" instead of "chunk-chunk" is simply not an option :lol:
Just to make sure I'm understanding the trick as described above: Is this schematic correct?
grrrunge
Has thanked: 59 times
Have thanks: 207 times
Postby DrNomis » 02 Jun 2012, 12:50
Pretty interesting and cool ideas here, I must do some breadboarding of this someday.... :hmmm:
DrNomis
Has thanked: 123 times
Have thanks: 405 times
Postby grrrunge » 02 Jun 2012, 13:17
DrNomis wrote:Pretty interesting and cool ideas here, I must do some breadboarding of this someday.... :hmmm:
I really want to get started as well! If it wasn't for all that damn painting i've got to get over with :slap: Moving is a pain in the ass :lol:
grrrunge
Postby IvIark » 02 Jun 2012, 13:27
Something like this?
For this message the author IvIark has received thanks: 6
atreidesheir (11 Jul 2012, 00:35), beedotman (04 Jun 2012, 09:39), blackbunny (02 Jun 2012, 16:41), joe_pineapple (10 Jul 2012, 18:54), Nocentelli (24 Jun 2012, 06:53), sinner (02 Jun 2012, 13:28)
IvIark
Has thanked: 668 times
Have thanks: 685 times
Next
Return to Transistors
