Okko - Diablo Boost+ (goop pics!!) [traced]
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
http://www.digimart.net/images/700/DS00298624_1.jpg
http://www.digimart.net/images/700/DS00298624.jpg
- soulsonic
The circuit board needs to take a bath. A chemical bath.
- briggs
I used to own one (without boost) and it had the thickest epoxy goop i've ever seen. The goop was hard enough to hold the PCB securely so I couldn't dare to trace it. It was quite versatile and covered a lot of grounds but lacked dynamics IMO. Pretty nice OD overall and looks really cool with that contoured face. I would guess it has ROG style fet-based circuitry.
- plexilover
Where can i get the BSIAB1 circuit? What are the differences to the BSIAB2?
A stock BSIAB2 will not produce the sound of the Diablo. The Diablo is a very heavy modded BSIAB2 with a lot of finetuned part values. The tone is generated by this mods and the Diablo sounds way different compared to the bland sounding BSIAB.
JHS
JHS
- seniorLoco
its rocket science i tell you modding the Bsiab2....
- soggybag
- Completed builds: Fuzz Face, Tone Bender, Big Muff, ICBM, Ugly Face, Green Ringer, Super Fuzz, Multiplex Echo, Multiplex Jr, Rebote, Echo Base, SHO, Fuzz Factory, Titan Boost/Octave, Easy Face, Tone Bender MkII, Trem Shifter, Zero Point Mini...
- Has thanked: 28 times
- Been thanked: 27 times
- Contact:
The description talks about a charge pump option. BSIAB probably sounds pretty good at 18V.
Blog: http://super-freq.com
- plexilover
Again, anyone who have the BSIAB1 schematic? What are the differences between BSIAB 1 and 2?
Anyone out there who modded a BSIAB?
I think the term "bsiab" in this sense is used improperly. The Okko Diablo, I'm sure, uses cascading miniboosters (revealed to DIY'ers by Jack Orman) but other than that, I suspect it shares little else with the BSIAB or BSIAB2.
I urge anyone to experiment with a breadboard and fets. The minibooster is high gain, self-biasing and sounds great. When overdriven, I find it sounds much more natural than diodes clipping. There are many avenues for tone shaping.
Look up also Aron Nelson's booster 2.5 and Doug Hammond's Sweet Thing schematics for more examples.
- soulsonic
Bumping this to attach the schematic. I don't remember who traced this one or where I found it... I think I found it at Das Musikding... maybe Kusi traced it?
Anyway, I hope it is okay with the author to post this here.
- OKKO_Diablo+.pdf
- (60.21 KiB) Downloaded 4661 times
- soggybag
- Contact:
Is that two mini-boosters followed by a BMP tone control? Similar to the BSIAB. The more channel looks more interesting, especially the bass control.
soulsonic wrote:Bumping this to attach the schematic. I don't remember who traced this one or where I found it... I think I found it at Das Musikding... maybe Kusi traced it?
OKKO_Diablo+.pdf - LEVEL 10kk??? It is an error? Can should be 100k?
Hi. in the original pedal, there is a selectable charge pump inside (for a 18V supply);
according to the scheme of the power supply posted in pdf, where the charge pump should be placed? For example can I use the charge pump of geofex
http://www.geofex.com/circuits/+9_to_33.htm
before the entire circuit?
