Colorsound - Power Boost / Overdriver
Postby pf_fan » 10 Feb 2008, 16:45
Bernardduur, any updates? :)
pf_fan
Have thanks: 5 times
Postby Bernardduur » 11 Feb 2008, 19:34
Sorry, I had a wedding in Finland this weekend, so I just came home. Hope to check it tomorrow as I haven't slept in days.......... 3 days of beer, Finnish women and sauna :)
Bernardduur
Has thanked: 87 times
Have thanks: 504 times
Postby bajaman » 11 Feb 2008, 21:18
lucky boy :lol: :wink:
Has thanked: 467 times
Have thanks: 1656 times
Postby pf_fan » 11 Feb 2008, 21:26
Indeed... ;)
pf_fan
Postby jg » 11 Feb 2008, 22:58
pf_fan wrote:
I think that I noticed one more thing. I counted 15 resistors on PCB. Schematic have only 14. To make things more complicated I found another picture of the PCB which has... 16 resistors! I circled this additional one :)
Looks to me like it is a 100K on the jack side of the .22uF output cap. "Anti-pop".
jg
Have thanks: 9 times
Postby Bernardduur » 11 Feb 2008, 23:18
Yes, that was it! I added it to the unit's notes underneath the picture. There is a 1M resistor used as a pull down on the input.
Now, do we miss anything?
Bernardduur
Postby pf_fan » 13 Feb 2008, 11:50
Bernardduur wrote:Now, do we miss anything?
Looks clear to me. But here's yet another picture of the Power Boost's PCB where two additional resistors goes from PCB to volume pot. Other one is connected between switch and PCB. Any ideas? Are they 'anti-pop' resistors as well?
pf_fan
Postby Bernardduur » 13 Feb 2008, 12:18
The ones to the volume pot sets the volume range. The volume can't go to absolute 0, the other one attenuates the signal a bit.
Mine doesn't have those.
Bernardduur
Postby pf_fan » 13 Feb 2008, 14:33
Once again, big thanks for your help!
pf_fan
Re: Colorsound - Power Boost / Overdriver
Postby pf_fan » 23 Jul 2008, 19:58
Bernardduur, On your schematic "Gain" pot is 2k2 linear (labeled 2K2A) and wired backwards compared to original schematic (10k log). Is it working backwards too?
pf_fan
Postby Bernardduur » 23 Jul 2008, 20:47
pf_fan wrote:Bernardduur, On your schematic "Gain" pot is 2k2 linear (labeled 2K2A) and wired backwards compared to original schematic (10k log). Is it working backwards too?
Nope....... maybe I misplaced the potmeter but it works in the normal way
Not that it adds that much. More like on 95% suddenly the gain kicks in :)
Bernardduur
Postby pf_fan » 23 Jul 2008, 21:05
Maybe a different value of the pot will help? I've seen Power Boosts/Overdrivers with 2k2, 10k and 470k pots...
pf_fan
Postby Torchy » 23 Jul 2008, 22:44
2K2A is actually a log pot. Which would explain why all the action takes place at one end of the travel ?
Torchy
Postby patafix » 24 Jul 2008, 09:00
Always the same :
With pots it's hard to find the right curve : xxA can be either a log or a lin... europeans and americans using a different letter to describe the pot...
Patafix... so sticky
patafix
Have thanks: 3 times
Postby pf_fan » 24 Jul 2008, 10:06
Torchy wrote:2K2A is actually a log pot. Which would explain why all the action takes place at one end of the travel ?
I think patafix is right - look at this picture:
It's 2k2A but there's LIN written next to it...
And a small collection of various Gain/Volume pots from Power Boosts/Overdrivers (both vintage and reissue):
http://img213.imageshack.us/img213/6380/05vb0.jpg
http://img529.imageshack.us/img529/3607/01kd0.jpg
http://img522.imageshack.us/img522/4599/03vl0.jpg
http://img515.imageshack.us/img515/6153/04qw1.jpg
pf_fan
Postby Torchy » 24 Jul 2008, 14:07
Youre right, sorry - I just read the 2k2A code.
Those look like Omeg P16's :- european made so they follow the european "standard" of A=Linear, B=Log. Total pain in the arse when the rest of the world follows the USA standard A=Log, B=Linear so why they go against the majority of manufacturers beats me. Typical european arrogance I suppose. Having multiple "standards" for the same thing seems an oxymoron to me.
http://www.omeg.co.uk/pc6bubrc.htm
Torchy
Postby analogguru » 24 Jul 2008, 14:24
Hey, Hey, Hey.....:
This is NOT US-standard, this was "invented" by the Japanese.
And the "european standard" was invented long before that - by Radiohm. And it would make more sense: Standard is linear so "A", logarithmic gets "B" and Rev.Log gets C.
Only some stupid guys couldn´t keep this in mind defined logarithmic as "A" - like "Audio Taper".
Have thanks: 117 times
Postby clintrubber » 08 Apr 2009, 04:06
I've seen various layouts, or could breadboard etc,
but does anyone know if ready made PCBs for this FX are around ?
clintrubber
Has thanked: 13 times
Postby controller700 » 09 Apr 2009, 09:07
Can someone give me an advice??
The Overdriver Schematic has three 25uF caps, but I can only find 22uF and 27uF caps... Which value should I use?
I´m going to use these files for my project:
Has anybody verified this??
controller700
Postby Bernardduur » 09 Apr 2009, 09:13
Just use 22 uF
Bernardduur
PreviousNext
Users browsing this forum: Google [Bot], MSN [Bot] and 3 guests
