Craig Anderton circuits
- modman
- a d m i n
- Has thanked: 4411 times
- Been thanked: 2139 times
Reposting the content from a thread that went off-topic and is archived now.
AG and Baja, thanks!
at http://www.muzique.com we can find the:
Anderton Frequency Booster schematic printed in GP June 1982
Anderton Wah-Antiwah schematic
Anderton Tube Sound Fuzz schematic
at http://www.paia.com we can find the:
Quadrafuzz
Stack in a Box
http://www.diyguitarist.com is offering the:
Anderton Volume Pedal de-scratcher with the original Guitar player article
http://www.synthdiy.com is offering the:
Anderton MIF printed in Contemporary Keyboard, Nov. 1979
Craig Anderton Compressor 1980
Quadrafuzz
Stack in a Box
- Meanderthal
Here's one I redrew from the EPFM book- The passive tone control:
ummm... ok, I'll try again when I get to 5 posts...
- modman
- a d m i n
Hi there,
welcome! you can use the test forum to get to 5 posts.
thanks for participating.
- modman
- a d m i n
- RLBJR65
HeadPhone Amp from EPFM
https://img126.imageshack.us/my.php?ima ... amphs3.gif
I'll redraw the other projects as I get time.
You still got to get the book for build notes, tweaks and mods
Project #1 Preamp https://img61.imageshack.us/my.php?imag ... ampgj0.gif
Project #2 Metronome https://img61.imageshack.us/my.php?imag ... omeuv6.gif
Project #3 Passive Tone Controll (posted Meanderthal) https://i86.photobucket.com/albums/k99/ ... vetone.jpg
Project #4 Head Phone Amp
Headphone amp layout. https://img267.imageshack.us/my.php?image=cahaik7.gif
Headphone Amp layout for 8 pin LM380N-8 https://img265.imageshack.us/img265/9606/caha8hv6.gif
Project #5 Mini Amp that uses an obsolete audio amp IC UA706 or TBA641B https://img412.imageshack.us/my.php?ima ... ampgm9.gif
Project #6 Ultra Fuzz https://img165.imageshack.us/my.php?ima ... uzzjd1.gif
Project #7 Bass Fuzz https://img106.imageshack.us/my.php?ima ... uzzqa0.gif
Project #8 Compressor / Limiter (posted ModMan) https://i197.photobucket.com/albums/aa2 ... or1980.jpg
Project #9 Ring Modulator https://img413.imageshack.us/my.php?ima ... torcd7.gif
Project #10 Dual Filter Voicing Unit (Thanks Andrew!) Added PS info https://img106.imageshack.us/my.php?ima ... filig7.gif
Project #11 Adding Bypass switches. Won't do that one.
Project #12 Guitar rewiring. Telecaster Rewire http://users.adelphia.net/~cygnusx_1/anderton_jpeg.html
Project #13 Bipolar AC Adaptor: + / - 9v Power supply https://img530.imageshack.us/img530/325 ... terux0.gif
Project #14 Treble Booster https://img374.imageshack.us/img374/131 ... ostwr4.gif
Project #15 Electronic Foot Switch https://img517.imageshack.us/my.php?ima ... otsro9.gif
Project #16 Tuning Standard. Uses obsolete MK50240 Tone generator not worth re-drawing unless someone wants it.
Project #17 Super Tone Control https://img201.imageshack.us/img201/778 ... trozr1.gif
Project #18 8 in, out Mixer. https://img402.imageshack.us/img402/483 ... xerlr3.gif
Project #19 Using an Ohm-Milliammeter. NAH!
Project #20 Practice Play Along https://img237.imageshack.us/img237/309 ... ppaab6.gif
Project #21 Phase Shifter https://img461.imageshack.us/img461/743 ... terto8.gif
Project #22 Making patch cords. NAH!
Project #23 Talk Box. NAH!
Project #24 Tube Sound Fuzz (posted Modman) http://www.geocities.com/CollegePark/Li ... 55/tsf.gif
Project #25 Envelope Follower
https://img166.imageshack.us/img166/935 ... oweql2.gif
Project #26 Spluffer, combination splitter buffer.
https://img530.imageshack.us/img530/449 ... ferji7.gif
Project #27 Noise Gate
WOW, that will keep me busy for a while, I forgot there were that many!
I'll do them in order unless someone has a request.
- RLBJR65
I'll just keep editing my post and bumping the topic when I add something.
- MoreCowbell
- Transistor Tuner
- MoreCowbell
- Transistor Tuner
- RLBJR65
Thanks Andrew! I added the PS info and re-posted.MoreCowbell wrote:ANDERTON DUAL FILTER VOICING UNIT
Posted Bass Fuzz
- RLBJR65
Balanced Ring Modulator (not the one in the book I have) http://www.lynx.bc.ca/~jc/pedalsBalancedMod.html
Stage Center Reverb http://www.montagar.com/~patj/screverb.gif
S.C.R. at GGG http://www.generalguitargadgets.com/ind ... &Itemid=75
- RLBJR65
Posted Ring Modulator & link to part of project 12 Telecaster rewire.
Buffer http://www.freeinfosociety.com/electron ... php?id=323
8 Watt Practice Amp http://www.generalguitargadgets.com/ric ... /craig.gif
- soulsonic
We should do a bunch of updated layouts for the circuit boards to accommodate current opamps, instead of those ones you can't get any more.
- RLBJR65
Agreedsoulsonic wrote:We should do a bunch of updated layouts for the circuit boards to accommodate current opamps, instead of those ones you can't get any more.
Nothing really special about the IC is there? http://www.datasheetarchive.com/img/pdf1.gif
I thought I saw the Super Tone Controll redone but can't seem to find it.
AC adaptor posted
- John Lyons
There are a few CA PCB layouts at General Guitar Gadgets.
They all have modern IC pin outs.
The super tone control is one of them.
By the way, The STC is a very nice Hi,low, band pass filter and does a nice wah filter when it's set up with a foot controled pot.
John
John
- RLBJR65
Thanks John! I knew I saw some of them before
http://www.generalguitargadgets.com/ind ... &Itemid=26
Also some from DIY Projects for Guitars http://www.generalguitargadgets.com/ind ... &Itemid=26
The SuperTone controll layout is still for oddball quad op RC or XR 4136 IC's but NTE997 should work, well at least the pinout is the same.
I know if I posted links to the schematics I've redrawn elsewhere, I would be chastised to no end and probably banned. Some of those layouts like the Metronome, Super Tone Controll and others are EXACT COPIES of the original PCB artwork from the book. Actually it's worse than that, they are copies less the original designers info Where is Jay when you need him
- RLBJR65
Even with schematics and layouts posted I would still recomend getting the book. You really need it to know what the intent of the designs were. The Ultra Fuzz for example is not your typical overloaded transistor or opamp type of fuzz. Don't build it if you are expecting it to do something you have heard before because you will be very disapointed.
I really hope that posting these schematics will actually draw more attention to the book!
- soulsonic
Me too - I think it's a great book and well worth having, especially for novices.RLBJR65 wrote: I really hope that posting these schematics will actually draw more attention to the book!
The Ultra-Fuzz is interesting - a square wave comparator fuzz. I haven't built that one, but I did build an earlier version of a comparator fuzz he designed that just used a single 741. I think the design in the Ultra-Fuzz gives better control over the gating action than the older circuit did. I'll have to give it a try, because I liked how that older one sounded.
- RLBJR65
Treble Booster added.
- RLBJR65
Added a layout for the Headphone Amp
