Colorsound - Power Boost / Overdriver
Re: Colorsound - Power Boost / Overdriver
Postby Electric Warrior » 10 Aug 2009, 15:16
pf_fan wrote:
Electric Warrior wrote:I just fought myself through dozens of Power Boost and Overdriver gut shots. Here's some variations of the circuit:
I hope you'll find those pics useful as well :)
http://www.megaupload.com/?d=S3OUCL39
sorry, nothing new that I can make out.
Maybe I should have mentioned in the shematic that the later Overdrivers have a 10µF cap at Q1's emitter..
Electric Warrior
Has thanked: 21 times
Have thanks: 89 times
Postby Rocket Roll » 10 Aug 2009, 16:28
I wonder - could anybody provide the original 18V Overdriver schematics and/or layout, so that we could use a 17V charge-pump (http://www.generalguitargadgets.com/ind ... &Itemid=26) to make a clone of it?
Rocket Roll
Have thanks: 34 times
Postby Electric Warrior » 16 Aug 2009, 20:07
guess what I did on page 4? :)
here's my layouts, I hope I didn't mess up too bad..
Electric Warrior
Postby blueduck577 » 17 Aug 2009, 04:25
i just built one of these off of the hand drawn overdriver schematic dated 6-14-71... and it doesn't sound like an overdrive to me at all. it does the clean boost but when it distorts it sounds more like a fuzz face to me. like others said it's sounds sort of splatty and misbiased. is this what it's supposed to sound like? i used 2N5088s for the transistors... I have some BC108s and some 2N2222s on hand also, though others have said the transistors don't make much of a difference.
it's late, so I haven't had the chance to crank the amp.
blueduck577
Postby Rocket Roll » 17 Aug 2009, 10:35
Electric Warrior wrote:guess what I did on page 4? :)
Great, thanks a million! Could you maybe make a PCB layout, if that's not too much to ask?
Rocket Roll
Postby Electric Warrior » 17 Aug 2009, 10:52
blueduck577 wrote:i just built one of these off of the hand drawn overdriver schematic dated 6-14-71... and it doesn't sound like an overdrive to me at all. it does the clean boost but when it distorts it sounds more like a fuzz face to me. like others said it's sounds sort of splatty and misbiased. is this what it's supposed to sound like? i used 2N5088s for the transistors... I have some BC108s and some 2N2222s on hand also, though others have said the transistors don't make much of a difference.
right, it's a boost. does yours sound anything like this? http://www.youtube.com/watch?v=69UZiByEGkQ
no, why don't you make one yourself?
Electric Warrior
Postby Brink » 17 Aug 2009, 15:43
Rocket Roll wrote:Great, thanks a million! Could you maybe make a PCB layout, if that's not too much to ask?
One already exists: http://www.aronnelson.com/gallery/main. ... alNumber=3
Brink
Has thanked: 10 times
Have thanks: 20 times
Postby jrod » 17 Aug 2009, 16:19
For this message the author jrod has received thanks:
bossman (14 May 2018, 20:29)
jrod
Has thanked: 337 times
Have thanks: 42 times
Postby Electric Warrior » 17 Aug 2009, 16:53
these are all for the Overdriver. Rocket Roll was looking for Power Boost layout, which is not 100% compatible with the Overdriver PCB layouts posted. The 12k resistor at Q1's emitter connects with Q2's collector in the power boost.
For some reason the .1µF capacitor across the bass pot is missing in those layouts.. :hmmm:
Electric Warrior
Postby blueduck577 » 17 Aug 2009, 19:49
this thing doesn't like buffers. running direct guitar -> overdriver -> amp sounds fantastic. but when I inserted it in my signal chain after a boss SD-1, it became splatty and had treble emphasis. maybe thats why I felt it sounded misbiased earlier.
oh well, looks like it's going to replace the SD-1 anyway, and all of my other pedals are true bypass. maybe I'll just put it first in the chain. either way this thing sounds great with the amp going full tilt.
blueduck577
Postby .Mike » 30 Sep 2009, 04:40
Hey guys,
I put together an original layout for this using the "Overdriver" schematic, and thought I would share. It's kind of niche layout, so it won't be suitable for everyone. This is the second layout I have ever done.
This is for a long-term multi-effects unit I'm building for myself. I will do at least 10 different original layouts when all is said and done. I'll be posting the project files for each as I compete them. All of my layouts will have: Board-mounted pots (meant to mount vertically); Volume pot on top; 4" x ~2" max dimensions; and Molex jacks for in/out/power/ground connections. I've already released my PIC tremolo, but it disappeared a while back and I haven't had a chance to repost it yet.
Anyway, here are all the files for anyone who is interested:
CSOD.zip
I've included: ExpressPCB files (.pcb, .sch); PDFs of the PCB, SCH, toner transfer, layout, and pseudo-silkscreen; images of etched board; images of completed build.
For the pseudo-silkscreen (fakescreen?), I toner transfer it onto the component side using photo paper, soak, and rub off all the paper except a thin layer to make it legible on the component side. If you do this, make sure you flip the image to reverse it.
Finally, here are some photos in case you just want to look: link.
Enjoy! :)
Mike
My website: America's Debate | My effects site: Just one more build...
For this message the author .Mike has received thanks: 3
BQmusic (17 Apr 2015, 19:49), Flaconsius (01 Nov 2013, 23:38), pinkjimiphoton (13 Oct 2011, 00:55)
.Mike
Have thanks: 32 times
Postby yeeshkul » 17 Nov 2009, 21:18
Guys is there any chance to find out whether Gilmour's Power Boost (1972 - 1977) was 9V or 18V version?
yeeshkul
Have thanks: 2 times
Postby TheLemon » 30 Dec 2009, 06:35
yeeshkul wrote:Guys is there any chance to find out whether Gilmour's Power Boost (1972 - 1977) was 9V or 18V version?
It was probably 18v, the version i cloned mine after
TheLemon
Have thanks: 21 times
Postby jzilla » 30 Dec 2009, 07:46
Dr Tony Balls wrote:yup!, used this vero layout, which checked out against the original schematic that you posted.
http://aronnelson.com/gallery/main.php/ ... d.jpg.html
i'm thinking of trying this for my first stripboard build. can someone tell me what the red squares on the stripboard represent? eg one is above the left transitor. another to the right of R3.
many thanks!
-j
jzilla
Postby SPeter » 30 Dec 2009, 09:08
many thanks!
-j
The red squares show where to cut the strips!
:D
SPeter
Have thanks: 76 times
Postby jzilla » 30 Dec 2009, 10:11
many thanks!
-j
:D
thanks!
jzilla
Postby GeekMacDaddy » 30 Dec 2009, 12:30
The layout calls for a 200pf cap. I replace that with (or you could put on a switch) a 470pf, and it gives the pedal it's missing bottom. :D
GeekMacDaddy
Have thanks: 5 times
Postby jzilla » 30 Dec 2009, 18:40
GeekMacDaddy wrote:The layout calls for a 200pf cap. I replace that with (or you could put on a switch) a 470pf, and it gives the pedal it's missing bottom. :D
thanks for the tip! what size enclosure would you recommend using btw?
jzilla
Postby GeekMacDaddy » 30 Dec 2009, 18:46
Should fit into anything.
GeekMacDaddy
Postby jzilla » 30 Dec 2009, 19:03
GeekMacDaddy wrote:Should fit into anything.
oh yeah? even a 125B? for some reason i was under the impression it needed a bigger enclosure...
jzilla
PreviousNext
