I'm redoing the preamp on an older Yamaha classical guitar. The pots are push-latching and recess back into the body when in the down position.
So, here goes. I'm looking for a pair of 100k push latching pots with 3.5mm shaft, d-flatted, pcb/pin termination. At this point, I'm not particular about the taper or tolerance, and could even work a bit either way on resistance.
