Thanks for any help you might afford me.
Best type of power supply
Are there any reasons not to use a switching-mode power supply as opposed to a conventional magnetic transformer to power my pedalboard and stompboxes?
- jimbob_400
Would you use one power supply to power lots of pedals? If so firstly make sure that a switching supply can supply enough current.
Some switching power supplies can be noisy.
Some pedals like isolated supplies, boss dd20 does from experience.
The visual sound 1spot is a good switching power supply with no noticeable noise issues and can supply plenty of current.
Thanks jimbob.
It's only a few pedals: TS9DX (8ma), TC PolyTune (45ma), my home made looper/AB box (appr. 50ma), and my midi foot controller (500ma).
I came across a free 9VDC 1.1A SMPS, and was basically just worried if it could damage anything.
So, if it's cheaply made it might create noise in the audio, otherwise good to go?
- mictester
Make sure that you don't get any nasty spikes when the supply starts up. I find that it's often a good idea to house the SMPSU well away from any high-gain circuits. Also it's often a good idea to add extra supply filtering and decoupling capacitors across the rails (best done where it goes into each pedal). One brand of PSU I used was a real pain for noise, but had a really stable DC output and plenty of current for the price (I can't remember which brand), and I put a half-wave RF low pass filter in the DC output line to cure the whistles!shockhazard wrote:Thanks jimbob.
