WTB - WTT: Burr Brown OPA2134PA and MAX1044/ICL7660
- mikemaddux
Looking for a Burr Brown OPA2134PA and MAX1044/ICL7660.....
Anyone got any? Looking for a couple of each......could get by with one of each.....
Can pay cash/paypal or trade 3PDT switches, enclosures, or other parts.....
- danielzink
- Completed builds: Too many: www.danielzink.com
- Has thanked: 8 times
- Been thanked: 27 times
Mike,
I've got 15 ICL7660 - they do not have the "s" suffix if it matters. If they'll work for you - let me know.
Dan
Dan
http://www.danielzink.com
MoonWatcher wrote: Silent ain't better. If someone cracks the shitwind, I want to know what's headed my way. Silence is for the library and the cemetery.
- mictester
The ordinary 7660 has a bit of a problem in some circuit - the clock frequency of the chip is low enough that it can mix with other signals in your circuit and cause heterodynes which you will hear as whistles in the audio. Not pleasant (they're never concordant!). The 7660S has the option of a much higher clock frequency (which is easier to filter off the supply rails) and doesn't cause your pedals to whistle along (out of tune) with the music!danielzink wrote:Mike,
Dan
- mikemaddux
mictester wrote:The ordinary 7660 has a bit of a problem in some circuit - the clock frequency of the chip is low enough that it can mix with other signals in your circuit and cause heterodynes which you will hear as whistles in the audio. Not pleasant (they're never concordant!). The 7660S has the option of a much higher clock frequency (which is easier to filter off the supply rails) and doesn't cause your pedals to whistle along (out of tune) with the music!danielzink wrote:Mike,
Dan
Ya...i've run ito that whistling problem before........
- danielzink
Yes. That's why I mentioned that they didn't have the s designation.mictester wrote:The ordinary 7660 has a bit of a problem in some circuit - the clock frequency of the chip is low enough that it can mix with other signals in your circuit and cause heterodynes which you will hear as whistles in the audio. Not pleasant (they're never concordant!). The 7660S has the option of a much higher clock frequency (which is easier to filter off the supply rails) and doesn't cause your pedals to whistle along (out of tune) with the music!danielzink wrote:Mike,
Dan
Dan
- mikemaddux
yep, got em....thanks
