SolaSound - Tone Bender MK1.5 [schematic]
This is my first go at this so please take it easy on me...I am thinking about building a MK1.5 Tone Bender, this is the layout I came up with....I could use another set or two of experienced eyes to help verify that this is at least a correct layout...also, I'm interested in possible transistor values from anyone who has built one.
- Greg
It's a Fuzz Fcae, so all conventional wisdom regarding Transistor gain applies here.
For me.. if you want something that'll sound great and clean up nicely,
I usually shoot for 80 to 95'ish for Q1, and around 100 to 120 for Q2.
Don't get too obsessive. There are no magic gains, and how it sounds will be dependent on what you put before it (pickup type, etc) and after it.
The one thing I'd suggest as a mod is to replace the 5uf cap on the input with something like a .47uf, unless you like it very bassy and woolly.
Thanks for the info, I figured it would be similar to a FF but wasn't sure because of the different component values...Greg_G wrote:It's a Fuzz Fcae, so all conventional wisdom regarding Transistor gain applies here.
Anyone care to comment on if the layout looks correct? Not sure if I was able to translate everything correctly from the schematic (the pics help, but dont tell the whole story).
- phibes
Missing a few cuts. Cut at B4 and C9. The output wire should be Volume Lug 3. Not sure if that's what you meant or not.
Ken
Ken- Electric Warrior
I've also got a layout for this one
Here's some sound clips:
Some say it supposed to sound more like a low gain MKII than a Fuzz Face.
Yep OUT should be LEVEL 3.....havent mastered the attachments yet...phibes wrote:Missing a few cuts. Cut at B4 and C9. The output wire should be Volume Lug 3. Not sure if that's what you meant or not.
Thanks as usual
I hate that you cant edit posts...oh well...I just need to cite my sources on the schematics, those were done by Mr. D*A*M..gotta give credit where credit is due, I thought they were at least signed by him but they are not....props go to him for sharing though.Taller76 wrote:Yep OUT should be LEVEL 3.....havent mastered the attachments yet...phibes wrote:Missing a few cuts. Cut at B4 and C9. The output wire should be Volume Lug 3. Not sure if that's what you meant or not.I'll fix everything as soon as I have built one...which may be a few weeks...
Thanks as usual
- beedotman
Cool mods implemented to MKI.5 circuit implemented by D.Main in latest "Copper Top" version of Sola Sound MK1.5 (or I.75
- pull-down cap on input of circuit as in MKII (propably standard 10nF value or something lower - 4700pF maybe?, but I bet on 10nF)
- 4K7 (I'm not sure value, but looks like 4K7 to me) resistor on Q1base to ground - again, similar trick as in MKII
Rest looks like stock MKI.5.
Changes done for better circuit stabilization when using OC75.
Worth trying in other fuzz face type circuits, too!
Amazing box finish and again beautiful inside work by D*A*M.
http://stompboxes.co.uk/forum/viewtopic ... &start=460
- phibes
The pull down resistor looks like 47K.
Ken
Ken- beedotman
Yes... now this red stripe looks more like orange stripe to mephibes wrote:The pull down resistor looks like 47K.
Built one of these on perfboard with some oc75's. tested it with my tele but for some reason it doesn't sound as fuzzy as it should, however if I put a clean boost before it I get a nice amount of fuzz. Wondering is there any way within the circuit to boost the input going in without building a seperate booster board? I've tried different input caps and the fuzz face trick of putting a 1k pot in series with the 470r resistor but to no avail. Any suggestions would awesome as I really don't wanna give up on it yet
I just built one like this too with the pull-down cap/resistor and OC75's (Q1=78hfe, 226mA Q2=107hfe, 105mA). With a 10K trimmer on the Q2 collector resistor, it only got as low as 6,2V and there wasn't much gain either. Biased at 4,5-5V though it has a nice amount of fuzz and sounds great! I had to go up to 11,5K for that.brwifrbo wrote:Built one of these on perfboard with some oc75's. tested it with my tele but for some reason it doesn't sound as fuzzy as it should, however if I put a clean boost before it I get a nice amount of fuzz. Wondering is there any way within the circuit to boost the input going in without building a seperate booster board? I've tried different input caps and the fuzz face trick of putting a 1k pot in series with the 470r resistor but to no avail. Any suggestions would awesome as I really don't wanna give up on it yet
- LucifersTrip
- my favorite amplifier: Companion Psychedelic Machine
- Completed builds: Mosrite Fuzzrite (Si), Mosrite Fuzzrite (Ge)[2], Get Lo-Fi Fuzz, Fuzz Face (Ge) [2], Fuzz Face (Si) [3], Mos-Face, Vox Tone Bender, Kay Tremolo, Os Mutantes Fuzz [2], Psychedelic Fuzz, Smokey Amp, Sunn Buzz, Jen Fuzz, Fancy Fuzzbox, Muff Fuzz (op amp) [2], Buzz Box, Fuzz King, Rangemaster [5], Maestro FZ - 2/3, Ruby Amp, Orpheum Fuzz (Ge) [4], Great Destroyer, Schizo, Carlsbro Suzz, Shin-Ei Companion Fuzz (si), DOD 250 Gray [2], Super Dirt Fuzz, Fuzz Factory, Jordan Boss Tone, Sam Ash Fuzzz Boxx, Heathkit TA-28 Fuzz, Olson New Sound Fuzz, LRE Fuzz Sound, Green Ringer, Vox Super Beatle (Ge), Colorsound One Knob (Ge), Demon Buzzz [2], Demon Wasp v1, Demon Wasp v2, Super Hard-On, Bazz Fuss, Burns Buzzaround [2], Selmer Buzztone, Shin-Ei Companion Fuzz (Ge), Fuzz Face/FY-2 (Ge), Zonk Machine, Univox Squarewave, Demon Fuzzz, Mosrite Fuzzrite BG-500/1000 (Ge), Univox Superfuzz, Marshall Supa Fuzz, Demon Monster, AA Overdrive/ Retro Fuzz, Tone Bender MKII, Psychtar, Jordan Vica Vibe, etc...
- Has thanked: 19 times
- Been thanked: 70 times
- Contact:
speaking of voltages, beedotman, did you take note of the voltages in the D*A*M "Copper Top" you just posted about?
- beedotman
i don't own itLucifersTrip wrote:speaking of voltages, beedotman, did you take note of the voltages in the D*A*M "Copper Top" you just posted about?
- beedotman
maybe to much gain and leakage, especially for Q2. Try lower hfe for both.DonDougie wrote: I just built one like this too with the pull-down cap/resistor and OC75's (Q1=78hfe, 226mA Q2=107hfe, 105mA). With a 10K trimmer on the Q2 collector resistor, it only got as low as 6,2V and there wasn't much gain either. Biased at 4,5-5V though it has a nice amount of fuzz and sounds great! I had to go up to 11,5K for that.
Thanks! I have 60 for q1 and 82 hfe for q2 in there now, it biases up fine and behaves much better than before. The cleanup is smoother and the attack pot got significantly more of a usable range.beedotman wrote:maybe to much gain and leakage, especially for Q2. Try lower hfe for both.
- jalmonsalmon
So basically for a normal tonebender 1.5 schematic, I would just have like so:beedotman wrote:Cool mods implemented to MKI.5 circuit implemented by D.Main in latest "Copper Top" version of Sola Sound MK1.5 (or I.75):
IN --->>> 10n --->>> 5μf --->>> 47k going to base and take out the 100k resistor going to Q1 base that goes over to the Q2 emittor?
I want to try this one if that is how you do it LOL
- jalmonsalmon
Hey all, I put together something real quick that may work. Needs to be verified and I do not have all the parts to mess with this yet.
It is loosely based on that copper top Mk 1.5 with a bias pot and will work with your neg ground power - borrowed from a layout that IVIark did for a fuzz face but I changed the passive values
so it works for the tonebender mk1.5, or should LOL
If anyone that is in the know can sort of check this over for errors, for this is the 1st time I ever tossed a vero together.
- sinner
- Has thanked: 1031 times
- Been thanked: 907 times
Change the grid in DIYLC to 0,05"
You'll hit the potentiometer holes with wiring better.
