Alpha Right-Angle PCB Mounted Pots
snmavronis
Completed builds: My DIY stompbox builds:
- Neo-Classic 741 Overdrive (gray spec 250 Overdrive clone)
- MXR Distortion+ (diy replica pcb replacement 1980 block logo)
- Neo-Classic 3080 Compressor (script spec Dyna Comp clone)
Been thanked: 14 times
Post by snmavronis »
My only source for these Alpha pots is Small Bear Electronics but they are out of stock on the A100K that I need until October. So I'm looking for a steady source to get both of these 100K and 500K Alpha right-angle mount PCB pots for my 'gray spec' DOD 250 Overdrive clone circuit board that I etched. Does anyone else sell these two part numbers?
RV16AF-41-15R1-A100K (audio)
RV16AF-41-15R1-C500K (reverse log)
Image Image
Guitar > Boss NS2 Noise Suppressor > NS2 Send > MXR Custom Comp > Neo-Classic 741 Overdrive > NS2 Return/Output > VHT Special 6 Ultra Amp Input > Amp Send > MXR Carbon Copy Analog Delay > Boss RC3 Loop Station > Amp Return
Mich P
Has thanked: 59 times
Post by Mich P »
Here :
http://www.banzaimusic.com/Alpha-16-PC- ... k-log.html
http://www.banzaimusic.com/Alpha-16-PC- ... V-log.html
Contact them to be sure they are in stock,
they're is no stock on line so to avoid backordered parts and waiting
is preferable.
Mich P.
andersom
my favorite amplifier: Valvepower 18 watt
Has thanked: 37 times
Been thanked: 7 times
Post by andersom »
Maybe here?
http://www.musikding.de/index.php/cat/c ... mount.html
they are pretty fast and have a good service.
snmavronis
Thanks a bunch Mich P. and Andersom. I'm in the USA so not sure how overseas shipping would work with the cost and that 19% VAT tax ouch!
I have an workaround solution. A moderator from BYOC suggested doing this:
That might not be a bad alternative. I think this will be an excellent alternative and thanked him. For replacement pots to solder legs to like in the photo above, I think these will do from PPP:
(7524) Alpha Single-Gang Reverse Taper 16mm C500K Potentiometer
(7501) Alpha Single-Gang Audio Taper 16mm A100K Potentiometer
snmavronis
snmavronis wrote:I'm looking for a steady source to get both of these 100K and 500K Alpha right-angle mount PCB pots.
Over the past few days I made an email inquiry Pedal Parts Plus to see if they could stock some additional parts because Small Bear Electronics was temporaily out of stock on Alpha angle mount pots I needed and wouldn't get anymore in until October. I also provided my parts list to PPP as reference to see what they can do. I just hate being dependant on a sole source for special items. PPP emailed me and they are now going to start stocking those same Alpha pots that I need too! They should start getting these in about 6 weeks and will keep them in stock. So now there will be 2 sources (Pedal Parts Plus and Small Bear Electronics) for these pots in the USA.
Audiosculpture
Post by Audiosculpture »
Does Mouser stock any of the 16mm alpha pots that PPP or Small Bear stock?
snmavronis
I checked, Mouser doesn't have the exact same part number prefix RV16AF-41-15R1-[value]
