Alpha Right-Angle PCB Mounted Pots
Posted: 07 Aug 2010, 17:29
by snmavronis
My only source for these Alpha pots is Small Bear Electronics but they are out of stock on the A100K that I need until October. So I'm looking for a steady source to get both of these 100K and 500K Alpha right-angle mount PCB pots for my 'gray spec' DOD 250 Overdrive clone circuit board that I etched. Does anyone else sell these two part numbers?
RV16AF-41-15R1-A100K (audio)
RV16AF-41-15R1-C500K (reverse log)
Re: Alpha Right-Angle PCB Mounted Pots
Posted: 08 Aug 2010, 10:34
by Mich P
Here :
http://www.banzaimusic.com/Alpha-16-PC- ... k-log.html
http://www.banzaimusic.com/Alpha-16-PC- ... V-log.html
Contact them to be sure they are in stock,
they're is no stock on line so to avoid backordered parts and waiting
is preferable.
Mich P.
Posted: 08 Aug 2010, 12:20
by andersom
Maybe here?
http://www.musikding.de/index.php/cat/c ... mount.html
they are pretty fast and have a good service.
Posted: 08 Aug 2010, 14:52
by snmavronis
Thanks a bunch Mich P. and Andersom. I'm in the USA so not sure how overseas shipping would work with the cost and that 19% VAT tax ouch!
I have an workaround solution. A moderator from BYOC suggested doing this:
That might not be a bad alternative. I think this will be an excellent alternative and thanked him. For replacement pots to solder legs to like in the photo above, I think these will do from PPP:
(7524) Alpha Single-Gang Reverse Taper 16mm C500K Potentiometer
(7501) Alpha Single-Gang Audio Taper 16mm A100K Potentiometer
Posted: 11 Aug 2010, 14:10
by snmavronis
snmavronis wrote:I'm looking for a steady source to get both of these 100K and 500K Alpha right-angle mount PCB pots.
Over the past few days I made an email inquiry Pedal Parts Plus to see if they could stock some additional parts because Small Bear Electronics was temporaily out of stock on Alpha angle mount pots I needed and wouldn't get anymore in until October. I also provided my parts list to PPP as reference to see what they can do. I just hate being dependant on a sole source for special items. PPP emailed me and they are now going to start stocking those same Alpha pots that I need too! They should start getting these in about 6 weeks and will keep them in stock. So now there will be 2 sources (Pedal Parts Plus and Small Bear Electronics) for these pots in the USA.
Posted: 23 Aug 2010, 19:56
by Audiosculpture
Does Mouser stock any of the 16mm alpha pots that PPP or Small Bear stock?
Posted: 24 Aug 2010, 18:02
by snmavronis
I checked, Mouser doesn't have the exact same part number prefix RV16AF-41-15R1-[value]
