Fuzz Factory Build
ricardo_sousa11
Post by ricardo_sousa11 »
Hello , :D
As you can see i am new to this forum , but i have been with the idea of making myself a Fuzz Factory DIY pedal for a long time. I will be following this ( http://membres.multimania.fr/davpseudo/ffactorx.htm ) and I have some things i would like someone to help me with.
First off , here's my shopping cart so far :
Total Price : €12,75
I would like anyone with experience to check it and see if its all good , since its my first build i dont want to screw it up :scratch:
Now the more important ones :
- I will be purchasing some AC128 , but which HFe should i Choose ? Should i go for the middle ? Highest ?
- The capacitors ( Condesateurs ) , The Electrolytics are Radial Standard ? Or Bipolar ? or any other kind ?
- Also i Cannot find some 100nF ceramic capacitor , is there alternatives in film foil ? or any other ? if so , what brand should i get ?
I would deeply appreciate if you could link to http://www.banzaimusic.com and check at least the capacitors since i dont have anyone to help me with those.
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
Moved to a more appropriate area. :)
ricardo_sousa11
culturejam wrote:Moved to a more appropriate area. :)
Thank you , i didnt know where to put it.. :scratch: :mrgreen:
ricardo_sousa11
Also , press on the image cause its cutted
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
100nf I'd def go for a Film cap; they come in little 5mm spaced boxes.
http://www.banzaimusic.com/WIMA-MKS4-100nF-630V.html
Standard electrlytics are polarized radial, for our purposes 16 or 25v.
One more thing to note: you WILL cock this up and order something wrong. Prepare yourself for this fact now (although asking was a good start :) )
Do you not fancy a 9V 2.1mm socket for powering from a power supply? Do you have a case? Are you building on a PCB, veroboard, perfboard?
ricardo_sousa11
Hides-His-Eyes wrote:100nf I'd def go for a Film cap; they come in little 5mm spaced boxes.
Well thank you for advising me that Capacitor :D , i will be looking for the electrlytics now , a friend which is electrician will help me with the montage of this tough he said for me to get all the pieces that i needed , and he would help me with the soldering.
I dont want to loose money , so this needs to work , it will be mounted on a perfboard i guess ( those with holes in it ), and the case will either be Blue acrilic ( in this case with a LED inside ) or aluminum ( probably without the LED ).
Hey did you check all the other components according to the list ? thats what im most afraid of , if any item is wrong i'd rather if someone could check this for me.
Edit : What do you think of these for the 10uf http://www.banzaimusic.com/10uF-63V-Radial.html ? are they the right kind ?
DaveKerr
my favorite amplifier: Ampeg M-15
Dynacord Preference 500
Completed builds: Fuzz Face (2)
Tonebender MKII (3)
ROG Tri-Vibe
PAiA Ring Mod kit
Rangemaster
CNO
ROG Splitter-Blender
Clari (Not) cubed deluxe
Has thanked: 53 times
Post by DaveKerr »
I'd suggest going with a better 9v battery snap - the T style usually work better when the battery is loaded on its narrow side, and it's worth a few pennies more to get a molded plastic termination instead of the soft one shwon.
