Potentiometers values
diodead
my favorite amplifier: Egnater renegade 410
Post by diodead »
I understand the function of pots as a resistor and all, but what I'm missing is, how would one select a value for one?
I've seen common use for 100k A and B. But when is it where I would select 5K as opposed to 500K?
I'm assuming (dangerously) it's the same process as selecting the right resistor,
Could someone drop some science on me?
:secret:
yes. depending on how you set them up, pots are either variable resistors or variable voltage dividers. a normal volume control is a voltage divider, a pot set up from lug 1 to lug 2 or something similar is a variable resistor.
this seems like a good link-
http://www.bcae1.com/potentio.htm
and here's a video-
in order to understand what size pots to use, you have to understand what a voltage divider does, and what changing resistor values will do. it all depends on the part of the circuit they are used in.
diodead
Post by diodead »
Thanks for the link! I'm still waiting for an Ah-Ha moment where I understand . :blackeye
