Dean Markley Overlord switching problem
nbabmf
Post by nbabmf »
I have the starving tube version that is basically a rehoused Tube Driver, not the newer solid-state one. The pedal powers up and signal passes through in bypass, but the footswitch doesn't engage the pedal. From what I understand, it's a momentary switch that operates FET switching. I had a feeling that was the case and then I read through this thread: http://music-electronics-forum.com/show ... php?t=1553
Here are my questions:
- Could I just replace the existing switch with another momentary or are there specifications I should try to find first?
- How is the bypass on this pedal? I could probably just TB it with the information from that thread I posted but should I?
- Does anyone have a 12AU7 they aren't using, for when I have it working?
According to the schematic postet here:
https://i43.photobucket.com/albums/e374 ... dschem.jpg
it seems to be a precurser of this:
http://analogguru.an.ohost.de/193/schem ... po_901.gif
There is a lot about the switching discussed in the mentioned thread.
Yes, but it should fit mechanically...
According to the schematic it is not truebypass, it is a (buffered) fet-switch.
- Does anyone have a 12AU7 they aren't using, for when I have it working.
As you can see in both schematics a 12AX7 (7025, ECC 83) is used in the pedal.
nbabmf
Post by nbabmf »
I should have ordered one more 3PDT...
nbabmf
Post by nbabmf »
I opened the pedal up and examined it just now. The switch is definitely the problem. I hope I am explaining this right... when I press the button, the switch body is pushed apart by the shaft of the actuator, and no electrical contact is being made. I superglued part that was separating and let it sit for a few minutes. I plugged the pedal in and tried it again... nothing. I noticed that separation was occurring yet again on a different part of the switch body.
Thank you, Dean Markley, for using cheap-ass switches.
I do have a 3PDT I could put in there, but the hole from the existing switch is a big larger than the shaft on the 3PDT, so I'd need a couple larger washers. Goddamn.
Has thanked: 218 times
Been thanked: 857 times
nbabmf wrote:Goddamn.
Chill,
Within 2 weeks from now you'll have all fixed with satisfcation. Enjoy the process getting there just as much as the result! :D
