Yamaha CMOS Overdrive (gut shots)
dai h.
Has thanked: 46 times
Been thanked: 12 times
Post by dai h. »
got this cheap in "junk" condition (which means something is defective). Seems to work and produce sound but having no point of ref. have no idea if it's healthy or not. Anyway, thought I'd disassemble to take some guts pics. Hope these are enough (for anyone wanting to make a schematic, etc.). I did bend over some of the parts so the values could be read(photographed), so I hope these are enough, but if anyone REALLY wants I'll take it apart again to take some more pics. (Too redundant, etc. then let me know and I'll delete the pertinent shots.)
near footswitch from front of C42__102 ceramic cap.JPG (711.94 KiB) Viewed 2335 times
near footswitch and HD14016BP IC_3.JPG (683.52 KiB) Viewed 2335 times
near footswitch and HD14016BP IC_2.JPG (726.19 KiB) Viewed 2335 times
near footswitch and HD14016BP IC.JPG (792.86 KiB) Viewed 2335 times
near DC input jack 16V 220uF.JPG (728.78 KiB) Viewed 2335 times
mini PCB parts side between 182 and 821 ceramics, R33_33k, R28_100k.JPG (869.5 KiB) Viewed 2335 times
LOW EQ pot 503 alt angle.JPG (729.81 KiB) Viewed 2335 times
LOW EQ pot 503.JPG (759.69 KiB) Viewed 2335 times
HIGH EQ pot 503_b.JPG (789.4 KiB) Viewed 2335 times
HIGH EQ pot 503_a.JPG (748.95 KiB) Viewed 2335 times
HIGH EQ pot 503 alt angle.JPG (753.79 KiB) Viewed 2335 times
HIGH EQ pot 503.JPG (830.44 KiB) Viewed 2335 times
from side of uPC1571C IC near several alu electros_bent over.JPG (813.95 KiB) Viewed 2335 times
from side of uPC1571C IC near several alu electrolytics_3.JPG (806.38 KiB) Viewed 2335 times
from side of uPC1571C IC near several alu electrolytics.JPG (779.34 KiB) Viewed 2335 times
from other side of uPC1571C IC near several alu electrolytics_2.JPG (827.55 KiB) Viewed 2335 times
from other side of uPC1571C IC near several alu electrolytics.JPG (780.13 KiB) Viewed 2335 times
back of mini PCB with control pots_trace side.JPG (1.03 MiB) Viewed 2335 times
above NJU4069UBD and uPC1571C ICs.JPG (940.54 KiB) Viewed 2335 times
above jacks around HD14016BP IC.JPG (799.43 KiB) Viewed 2335 times
dai h.
Post by dai h. »
gut shots continued:
PCB trace side global view.JPG (1015.09 KiB) Viewed 2328 times
PCB parts side global view.JPG (1.01 MiB) Viewed 2328 times
parts side mini PCB above IC10_NJM4558SD 5k6 22k.JPG (805.23 KiB) Viewed 2328 times
parts side mini PCB 182 and 821 ceramic bent up, R32_2k7.JPG (840.15 KiB) Viewed 2328 times
parts side mini PCB C33_50V680n alu electro.JPG (752.24 KiB) Viewed 2328 times
parts side mini PCB from front of NJM4558SD op amp.JPG (738.39 KiB) Viewed 2328 times
parts side mini PCB near brown ribbon cable 182 ceramic.JPG (746.31 KiB) Viewed 2328 times
parts side mini PCB showing 25V4u7 and 50V150n alu electros.JPG (765.43 KiB) Viewed 2328 times
parts side mini PCB showing 50V150n alu electro.JPG (752.44 KiB) Viewed 2328 times
parts side of mini PCB with control pots_2.JPG (857.6 KiB) Viewed 2328 times
parts side of mini PCB with control pots_3.JPG (827.21 KiB) Viewed 2328 times
parts side of mini PCB with control pots_4 showing 25V4u7 alu electro and 104B pot.JPG
parts side of mini PCB with control pots_4 showing 25V4u7 alu electro and 104B pot.JPG (754.95 KiB) Viewed 2328 times
OUT LEVEL pot 104B diff angle.JPG (811.5 KiB) Viewed 2328 times
OVERDRIVE pot 500K D.JPG (804.87 KiB) Viewed 2328 times
OVERDRIVE pot 504D.JPG (769.47 KiB) Viewed 2328 times
near in out jacks from back of NJM4558SD op amp.JPG (867.61 KiB) Viewed 2328 times
near in out jacks from front side of NJM4558SD op amp.JPG (795.13 KiB) Viewed 2328 times
near in out jacks front side of NJM4558SD and red 154 metal poly cap.JPG (783.65 KiB) Viewed 2328 times
near NJU4069 IC.JPG (864.65 KiB) Viewed 2328 times
okgb
Has thanked: 222 times
Been thanked: 38 times
Post by okgb »
Never knew they got in on that game ,
i gather if you say you're not sure if it's
working correctly , that you're not impressed with the sound ?
or what do you think ? can you describe the qualities ?
anyway thanks for the work with all the pix
[ love that curvy 70's look of the trace side ]
dai h.
Post by dai h. »
Yes, it didn't seem particularly impressive however " *my* setup" of SansAmp into a joemeek preamp isn't working (something is wrong with the joemeek) so possibly it would sound better, but I'm guessing it won't. If you want to listen to somebody's sound clip of one, I found a page:
http://gauze.s297.xrea.com/odb_cod100.htm
(It's from a site where a number of overdrives, distortions, etc. are compared with the same riffs--or at least I think that's the idea.)
The main site:
http://gauze.s297.xrea.com/odbmain.htm
okgb
Post by okgb »
For a short while i had the E.H. hot tubes
which came from a friend and his description
was one word " Caustic " which i agree
so i think it's easy to make a poor sounding cmos
these days broken sounds are more popular but guessing
this Yamaha comes from the 80's ?
Has thanked: 218 times
Been thanked: 857 times
okgb wrote: [ love that curvy 70's look of the trace side ]
Interesting remark since this is clearly post 70's CAD. :wink:
okgb
Post by okgb »
Yes clearly , i said " 70's LOOK "
actually it has a bit of the tron feel to it
[ not your typical Boss anyway ]
but not the total freehand taped look of japenese 60's / 70's
better ?
check out the artwork of the tc eq i posted to the 70's+
not sure of it's era ? but plenty curvy
dai h.
Post by dai h. »
mid to late 80s? (not sure. That's my vague recollection from seeing this "plasticky" series in magazine ads.)
There is, apparently the manual avail. on line:
http://files.effectsdatabase.com/docs/m ... od-100.pdf
(Something I wonder is, if (since this thing uses a lot of power) the people at the store tested it with a weak battery, got no sound and therefore they concluded it was "defective". I also got a totally passive A/B/tuner out switcher (also as "junk") which seemed a bit odd (but maybe a switch is bad or something--not sure because I actually haven't tried it yet. Also got a Yamaha Distortion and Guyatone Phaser--all too good to pass up for the price even if defective--which they were (Yamaha was resurrected with a new primary filter cap and batt. snap. Not sure what is wrong with the Guyatone which turns on but isn't passing audio.)
okgb
Post by okgb »
Curious specs for the yami cmos , wonder why they went for a slightly
different chip then the usual 4049 ?
I think you're on the right track for the others though
check power and continuity , look for obvious physical
things , good score
yamaha_cod-100.pdf
(205.74 KiB) Downloaded 324 times
GuitarlCarl
my favorite amplifier: anything tube
Completed builds: Ds-1 mods, SD-1 mods, Small Clone mods, Muff build, Axis build, various other transistor booster builds... I can build a badaxe harmonic perc, but I can't get a fuzzface to sound worth a crap!
Has thanked: 54 times
Been thanked: 29 times
Post by GuitarlCarl »
I wish i could find a pinout of that NJM4558SD ... I have one but Googled for a SIP 9 package pinout and failed...
I would really love a good datasheet archive without all the crap ads. :blackeye
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
GuitarlCarl
Da it looks like that... :blackeye Now if I could just find a pinout !!!
I think its pin 1 vCC, 2 A out, 3 A -in, 4 A +in, 5 vEE, 6 B +in, 7 B-in, 8 B out, 9 vCC
roseblood11
At least, that's what the PINOUT at page 3 of the datasheet says... :wink:
