For Sale/ For Trade, Various Parts from my Collection
Scruffie
Has thanked: 28 times
Been thanked: 169 times
Post by Scruffie »
Just clearing out my stock at the moment, All vintage parts are pulls, Germaniums were snipped rather than soldered out to protect them, all have an acceptable amount of leg length left and ICs of course still have the full legs as they are all socket pulls.
Prices are without shipping but all negotiable, can do discounts on several purchases etc. -
3 x Vintage CA3080E - Untested, taken from an old PCB but see no reason they wont work, most likely from the 70s, $6 each or £4
3 x TCA350Y 185 Stage BBDs - Untested again, not sure of the use of these but any old Synth guys might be in need of them for repairs, Gold pins, $15 each or £10
1 x Vintage (I guess around the 60's) Celestion Speaker - Tested as working, 25ohms rating, good for Rubys etc. $25 or £15
1 x Prof. Fabbed Bad Stone PCB - Untested layout so you get to guinea pig it (haven't got around to finishing mine) Slight knick on one trace but tests fine with a continuity meter, made for onboard pots and to fit in a 1590BB - Trade Only.
1 x LM3900N - Think someone said this would be useful for Synths, Untested - $5 or £3
Mullard Black Glass Transistors 2 x OC45, 1 x OC44, 1 x OC71 also 1 x Metal OC81 (No D Suffix) all known to work in the various Tone Benders/ Rangemasters I tested them in but no idea on hFe or leakage $8 each or £5 each - $15 or £10 for the OC81
1 x Mullard OA7 Germanium Diode (apparently this is a Gold Bonded Diode... yeah I don't know what that means but it looks cool as it's an all glass construction so you can see the internal fillament) Untested... really not a clue what this is worth, maybe someone can advise me.
S.E.C Production GET Germanium Transistors, all untested entirely 2 x GET873, 1x GET874, 3 x GET114, 1 x Mullard Production GET114 $35 or £25 for them all? By the way these have alot thinner legs than your usual transistor.
1 x NKT 254 Gold Legged & Can Transistor with a Green Sleeve $10 or £5
1 x NKT 155 Sardine Tin transistor, Untested $8 or £5
1 x BL3208 (14 Pin Package Version) BBD Chip, worked last time I used it before it was retired in favour of a V3205, taken out of a socket $5 or £3.
Various MAX1044 or ICL7660 if someone needs some... got too many, would trade for a LT1054.
Box of old Capacitors, Resistors etc that I snipped out of some old equipment, definitley not tested but fine upon appearence, lots of hunts and a few mustard caps and mainly Carbon Comp resistors all with varying amounts of lead length left... offer me something... or ask and i'll chuck it in with something else you buy, going in the bin otherwise.
Trade wise, interested in PCBs, home made or otherwise or anything interesting parts/ things you might have lying around... need 2 x MN3005 (Yeah I know, i'll be lucky... but I do have OC81Ds if that might sway someone... and a few other BBDs in the MN30XX Series) and 2-4 V3205s (MN3205s would be fine aswell but I don't value them above V3205s) and a single LM13600 & CD4009.
Pics on request... or when I get round to them, probably more parts to come as I sort everything through.
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
How much for MAX1044?
Scruffie
Post by Scruffie »
You're in the U.K. aren't you... £2 Sound fair? Plus £1.20 Postage Probably.
Scruffie
Post by Scruffie »
All my MAX1044 are now gone (I have 2 ICL7660 with no S Suffix if they're any good to someone, they can have them free with an order)
Scruffie
Post by Scruffie »
Pictures Added -
Price Drops
GETs $30 or £20 - Shipped, they all show Good in a simple transistor tester so they do still function.
Caps & Resistors going in the bin on Monday... dunno why you'd want them really but seems a bit of a waste.
EHX Bad Stone PCB is a 4 Layer Board by Express PCB.
Speaker $20 or £10 (Don't worry about the strange impeadence rating, i'm running one in my Ruby rated simmilarly and it sounds/works great)
Knock a Dollar/Pound or two off any other stuff if you want... fairly flexible, just want this stuff gone.
Scruffie
Post by Scruffie »
Adding an HPro PS200R 9V 300mA Power Supply (With 3V 100mA Socket, Cable for Use not included) for U.S. Sockets, I got sent it with a pedal I bought but being in the U.K... can't use it in our sockets $7 ? or Swap for a PCB
Got some vintage transformers from radios not shown aswell if someone wants them which might be useful for a deacy amp or something, don't know how to test them for ratings though.
GET Transistors (I checked these on a mutlimeter... I know that it wont always work for Germaniums but if anyone cares, they all read a stable 60-110hFe and one didn't read) & NKT155... will swap the lot for an Electric Mistress board from here http://www.4shared.com/document/wPcCxA3 ... N3007.html (and a TZF Board if you're feeling nice) or $16 (Only $2 a Germanium Transistor)
OC Transistors dropped to $6 or £4 each (Or Trade for V3205) OC81 $12 or £7.50
I'll throw the OA7 in with any order, first come first serve... Another bin job otherwise (Reads 311mV on the Multimeter)
Some BCE Pinout 70's Silicon Transistors... House Labelled so probably not alot of point in giving there Names, various hFes 150-220ish or 400ish could be useful for D*A*M Meathead clones - 5 for $2 (Look like this type if anyones interested in appearences http://www.diyguitarist.com/Images/MB-Transistor.JPG )
CA3080E & BL3208 now $4 or £2.50
Speaker (I think it was 5 1/2 Inches when I last measured it, will have to check)... $15 or £8, the one in my Ruby really does sound nice but I have several of these and no need for more Rubys, Cone is in good condition (Dust cap has fallen off though)
Wouldn't be adverse to swapping my TCA350Y BBDs for a MN3006 or MN3009 (I read they can be used in place of MN3009 here - https://www.diystompboxes.com/smfforum/ ... ic=19510.0 but I wouldn't know how to) certainly a rare chip now, I think these were the first BBDs produced.
Anyone in the U.K. in need of a Reverb tank... I have one, with the full circuit still inside, just missing a transformer (and the front panel... you'll have to work out what all the knobs and jacks are for... might even be a full solid state amp) could also just take the spring out and sell that seperatley.
Hides-His-Eyes
what model is the reverb tank?
Scruffie
Post by Scruffie »
Hides-His-Eyes wrote:what model is the reverb tank?
All the outside information is missing (it's basically a blank metal chassis), the only thing I could find out was the words "Maine Electronics U.K." on the PCB.
Any picts of it buddy?
Scruffie
Post by Scruffie »
Here we go -
Board says -
Maine Electronics
Musician
200P
Issue 2
Duckman
Has thanked: 320 times
Post by Duckman »
The Bad Stone PCB looks very well :wink: I hope your not selling mine :lol:
Scruffie
Post by Scruffie »
Duckman wrote:The Bad Stone PCB looks very well :wink: I hope your not selling mine :lol:
Hehe, nah, yours should be somewhere over the atlantic right now...
Scruffie
Post by Scruffie »
I gave in and did the Leakage Tests for the Germaniums, readings are approximate and I hope I got it right... they seem to seem plausible (I couldn't be bothered to work out exact leakage so I got it in the ball park, I can give Voltage readings if you want to though)
GET874 - 91 hFe - Under 250uA
GET873s - 51 & 68 hFe - Under 100uA
GET114s - 60,58 & 55 hFe - Under 250uA
OC71 - 98hFe - Under 250uA
OC44 - 211hFe - Under 150uA
OC45 - 153hFe - Under 100uA
OC45 - 28hFe - Under 100uA
NKT255 - 93hFe - Under 600uA
OC81 - 56hFe - Under 600uA (High Yes but ToneBender MKIIs Like a Bit O' Leakage)
Other NKT155 & GET114 Were Dead
Found...
2 x Plastic PCB Mount Stereo Jack $3/£1.50
2 x BOSS Style Set Screw Knobs - $3/£1.50
2 x Mini Chicken Head Alen Key Fit Knobs - $3/£1.50
1 x RS 0.47uF 250V Cap $2/£1
1 x KIA6213S 9 Pin SIP Chip - Desoldered (Used in Marshall MS-2 and Other Mini Amps) $3/£1.50
Shipping for Small Airmail US Orders $3.50 Approx
Shipping for Small First Class UK Orders £1.50 Approx
Shipping for Small AirMail European Orders €2.50 Approx
Scruffie
Post by Scruffie »
Two Day Specials...
$40/£25 for all the Germaniums
$8/£5 for all the CA3080E
$4/£2 for all the Knobs (An extra $2/£1 for the Jacks too)
$3 for the Power Supply
$1/£1 for 5 Silicon Transistors
$8/£5 for the Speaker
$12/£7.50 for the Reverb Tank (£12 for the Whole Thing)
$3/£2 for the LM3900N
$3/£2 for the BL3208
$20/£15 for all the TCA350Y
$100/£65 for everything listed
Scruffie
Post by Scruffie »
GETs, NKT & Germanium Diode are Gone!
Bad Stone Board, Reverb Unit, Knobs, Random Vintage Parts & Jacks are Pending,
OCs are now $24/£15 the lot for the next day then back to $30/£20, all other prices stand.
Scruffie
Post by Scruffie »
Adding a Rev. 2 A/DA Flanger Clone PCB for the SAD1024, chip sockets installed (except for the 4049 space, accidently bought a 14 rather than 16Pin Socket for the space) Will include the 4047, 4049 & 4007 (Can also add random Quad & Dual Op-Amps if you want) The 5 Pots, Split Shaft (The 500kC is a 1M Linear, with the intent of using a 1M resistor across lugs 1&3 to approximate the 500k Rev Log) A 2N3819 FET (Suggested By Bajaman as a Better Replacment for the J201 in the circuit) and the 7815 Regulator (Not heatsink/Screw Mountable)
Asking £28.50/$44 which is what I paid for the board and components.
Had intended to build this up but got a MN3007 board and the SAD1024 had to be used to repair a vintage unit instead so I thought someone with a spare SAD1024 might like the opportunity rather than me using an MN3007 add on board.
Scruffie
Post by Scruffie »
Reverb Tank, Knobs & Jacks are Back for Sale, Bad Stone Still Pending, OC71 Gone.
Final Reductions, Everything's Gotta Go before I move.
£26/$40 Shipped for the A/DA Board & Parts £21/$32 Without Parts Shipped
£12/$20 The Last 4 Mullards (£3.50 or $6 Each)
£4/$6 For All the CA3080E
£2/$4 For all the Knobs & Jacks
$3 For the Power Supply
£1.50/$3 for the BL3208
£1/$2 For the LM3900N
£1.50/$3 for the KIA6213S
£3/$5 For the Speaker
£1/$1 For the Silicon Transistors
£1.50/$3 For the MAX1044
Scruffie
Post by Scruffie »
Speaker, Knobs, Jacks, 70s Silicon Transistors (Although I could find more on request, PNP or NPN BCE Pinout) All the Mullards, KIA6213S, All the CA3080 are gone (And the Bad Stone is Basically Gone)
Which Leaves -
$12/£7.50 for the Reverb Tank (£10 for the Whole Thing)
HPro PS200R Power Supply $3
1 x BL3208 £1.50/$3
1 x MAX1044 £1.50/$3
3 x TCA350Y BBDs £7/$10 Each
1 x OPA2134PA £2/$3
1 x NOS Full Legged Metal Can NKTOC44 (I'll Test it Before Sending to Check it's Good, Haven't had a chance yet) £4.50/$7
Trades, Still after a NJM or LM13600 & CD4009, CD4013, Right Angle Board Mount Pots, Those Mini Trimmer Pots (Like on Z.Vex Seek Pedals) 3 x V, BL or MN3102, 2 x NE,SA,V571 or NE570 & a MN,BL or V3207.
(Interested in MN3008 & MN3009 too if you have some)
