phase and output mixing with a blend/loop circuit
squrl
Post by squrl »
just not getting the hits at diystomp so i figured i'd try over here.
when dealing with a circuit such as the paralooper...
http://moosapotamus.net/THINGS/paraloop ... perSCH.gif
is it totally necessary to have the output buffer or will a simple passive mix section suffice?
if you connect the + input of U2-A to the - with a switch, will that work to invert the phase?
Mugshot
Post by Mugshot »
squrl wrote:just not getting the hits at diystomp so i figured i'd try over here.
im also working on doing a mixer based on the application notes of the TL084: having two-outs/send channels and mixed passively using a resistor (prolly 10K or 22K) to keep the phase non-inverting. not sure if that helped though. :wink:
signatures are for the weak.
FiveseveN wrote:
considering the low quality of the transistors and caps
Are Asian electrons inferior to American electrons?
squrl
Post by squrl »
not exactly... :|
the stages are passively mixed before the output buffer already - i was wondering more if it's really necessary to keep that buffer at the end?
as far as the phase goes, i'm looking for a simple way to invert the phase of one side - hopefully without adding another opamp.
