Testing Current Draw
railhead
Post by railhead »
Just picked-up a new DMM, and for the freaking life of me, I can't figure out how to test current draw. I have an old crappy needle meter and it's getting readings, so I know I have everything hooked-up properly, but no matter where I connect the leads or where I set the dial, I get nothing but -.02 on the display. The user manual is worthless, BTW.
The black lead goes to the common, and for mA, I would assume I should have the red hooked up to the mA jack. I get -.02. So I slap the red lead into the VohmF jack. -.02. This is an auto-range DMM, so there's no range dial -- and the Range button doesn't have any effect on things. Below is a pic of the DMM. Any help would be MUCH appreciated!
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
Do you have to set the AC/DC type of measurement with the button on the upper right or is it detected automatically too?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
railhead
Post by railhead »
That just made it +.01 or +.02
lolbou
Post by lolbou »
what if you use the µA position? What's the circuit you're testing?
railhead
Post by railhead »
No joy there, either.
I'm just wanting to check the current draw of my effects pedals is all. :cry:
lolbou
Post by lolbou »
Is the battery of the DMM ok? If it reads voltages and other stuff right, then it may be damaged?
railhead
Post by railhead »
Yeah, it's reading everything else properly. Do you agree that I should have the red lead in the ,ACx jack and the MDD set to mA on the dial?
On my needle MM, I can set the range to 5, 50, or 500 — but I don't know which line/scale to read on the panel.
railhead
Post by railhead »
Okay, when I hook up the red lead to the A jack on the DMM, I can see that the pedal's LED comes on — so the circuit is being completed. But, no matter where I turn the dial, I get no reading other than -.02.
minnow
Has thanked: 27 times
Been thanked: 16 times
Post by minnow »
For current draw measurement, unplug the red probe from the "ohm" port.
Then connect the red probe to "mA". Black probe remains at "COMMON"
Now you should see the meter alive when taking current readings :P
railhead
Post by railhead »
minnow wrote:For current draw measurement, unplug the red probe from the "ohm" port.
When I hook up to that port, the LED doesn't come on — so I assume the circuit isn't being completed. I'm beginning to think my DMM may be messed up...?
minnow
Post by minnow »
Ok, how do you measure current draw?
This is what I do:
Hook up the pedal with the input jack connected (this will complete the circuit).
Un-snap one of the battery terminals (doesn't matter whether -ve or positive) leaving the other still connected to the battery (this will now "open" the circuit).
Use DMM, one probe on the battery (the one that is not connected to the snap) and the other probe on the snap (which is not connected to the battery).
Current draw should be displayed on DMM.
Current draw should differ when you turn on/off the effect.
Voltage reading - in parallel
Current reading - in series
If you're certain all the steps that you took are correct, the only way to be certain that your DMM is busted, is cross check with a working DMM.
:cry:
Hope that helps...
railhead
Post by railhead »
Yes, that's exactly how I test it.
The only way the LED lights to show the circuit is complete is when I put the red probe int the "A" port. If the red probe is in any other port, the LED does not light-up — which to me means the circuit is not completed. With the probe in the A port, all I get is -.02.
minnow
Post by minnow »
But now you have the needle MM and the DMM both unable to measure current draw?
YuGi
Been thanked: 25 times
Post by YuGi »
railhead wrote:The only way the LED lights to show the circuit is complete is when I put the red probe int the "A" port. If the red probe is in any other port, the LED does not light-up — which to me means the circuit is not completed.
I think the fuse in the mA port is broken.
railhead wrote:With the probe in the A port, all I get is -.02.
The sign minus is due to the inverted red-black probes, the .02 mean 20mA.. seems 0K to me for an effect, considering the rounding due to the scale in A (mA have more precision in this case).
railhead
Post by railhead »
minnow wrote:But now you have the needle MM and the DMM both unable to measure current draw?
No, the needle MM seems to be working fine.
railhead
Post by railhead »
SCORE!
The mA fuse was blown, so I'll be heading to Rat Shack to get a replacement.
minnow
Post by minnow »
:applause:
railhead
Post by railhead »
With this bugger of an issue, I did finally learn to read the old needle gauge, though, so that's good. :D
railhead
Post by railhead »
I popped a new fuse into the sucker, and everything works perfectly. Man, I thought I was going insane!
YuGi
Post by YuGi »
railhead wrote:I popped a new fuse into the sucker, and everything works perfectly. Man, I thought I was going insane!
:thumbsup
