I am particularly proud and pleased with this new project - I have just completed the working prototype - pictures to follow
I started this project by trying to reverse engineer the Demeter Compulator from pictures posted here by some of you folks, but I could not see the solder side of the board and despite numerous requests, nobody posted it
So, I quietly shelved this project and did some work on other projects, but yesterday a friend kindly provided me his unit to open up, and the rest as they say is history.
I got my trusty digital camera out and got some lovely pictures from all angles - I will post these soon, so do not panic.
Then I traced the schematic and was a little disappointed, because it did not seem to function like the LA2A limiter that I believed it was modelled after
Hmmmmmm, I thought - i can do better than this, i thought to myself, so I set to work and this is what I came up with. Although it shares some similar features and parts with the Demeter Compulator it functions completely differently - in fact it functions just like the Teletronix LA2A Limiter
THIS IS NOT A COMPRESSOR like the Demeter it is a LIMITER
The Demeter Compulator derives it's control signal from the OUTPUT of the unit. My Optical Limiter derives it's control signal from the INPUT of the unit and therein lies the major operating difference.
I have played some guitar through the Demeter Compul;atorand although it is a very nicely made unit I was less than impressed by - no indicator to show how much compression and a tendency to release erratically on high compression settings - a bit like an underdamped swing door
Nevertheless, Pete Townshend and Dave Gilmour both use one in their Pete Cornish rigs, so it cannot be that bad then can it
Anyway - I have a board layout and parts placement overlay all done for the compulator - I will tidy up the schematic and post it in the next few days, but I think you will like my Limiter better. Anyway I will post them both as projects and let you folks decide which one to build, or you can build them both if you are keen
Enough tlk - here is the first instalment in this project - the Baja Optical Limiter schematic - board layout and PCB will follow very soon , but as it is my Birthday tomorrow, I may be a wee bit incapacitated
enjoy
BAJA Optical LA2A Style LIMITER
