WTB: slide pots for boss GE7
Posted: 14 Sep 2010, 08:08
by the3secondrule
anyone?
Small bear dont stock 'em, and I got a bit lost searching on mouser...
I *think* its a 30mm w10k
Re: WTB: slide pots for boss GE7
Posted: 14 Sep 2010, 11:57
by the3secondrule
actually its 20mm travel.
have flicked an email to Boss, but I imagine they'll be cheaper elsewhere...
anyone?
Posted: 17 Sep 2010, 10:38
by the3secondrule
nudge, nudge?
Futurlec, Smallbear, Mouser don't stock 'em. Digikey have somethig which may or may not work, but they don't have the datasheet so I can check if it will fit (plus the minimum order is 1200 pieces)
Boss are being fairly uncooperative.
i guess i might be sh*t outta luck, huh? but I'd like to avoid having to buy and mod another Ge7...
Posted: 17 Sep 2010, 11:48
by salocin
A quick search turned up this:
http://www.shokaifareast.com/Products/M ... meters.htm
Slide Potentiometer - 20MM Travel
Carbon film 10K ohms linear taper (B taper) 15mm insulated plastic shaft panel mount 31mm between screw holes with solder lugs. Made in Taiwan.
Posted: 17 Sep 2010, 11:55
by salocin
Posted: 17 Sep 2010, 20:29
by the3secondrule
yeah, I had a look at those - the original one is only 6mm wide, finding something that is going to fit the available width seems to be the big problem.
also the original has 4 pcb pins arranged in a straight line..
probably my best shot at this stage is to find some one selling a dead ge7 I can use for parts
