BOSS DD2 or DD3 mods for tape echo sound
Bernardduur
Has thanked: 89 times
Been thanked: 645 times
Post by Bernardduur »
bajaman wrote:forget the switch - just do the mods and you will hear what they do :wink:
I added a simple DPDT switch to control the caps; made the most difference;
The cap across the level pot didn't do a lot on it's own (keeps it from oscillating), the other cap made a lot of difference in the treble response.
I LOVE IT!
moro
Post by moro »
Yeah, but the cool thing about this mod, IMO, is the potential to get digital and analog(-like) sounds out of one pedal.
switches are for doubting Thomas and knob twiddlers - insert one if you must BUT you won't use the stock setting once you hear what the mods do to the sound of these pedals :wink: :wink:
Bernardduur
Well, I like both now as they sound so different :)
And in the tape mode the unit won't oscillate
OrionManMatt
my favorite amplifier: AC30
Completed builds: BB Preamp, volume pedals, tap tempo boxes, etc.
Been thanked: 16 times
Post by OrionManMatt »
and what doing an effects loop out? (nod to keeley)
lefty
Post by lefty »
saved from a thread on diystompboxes:
Another cool mod is a feedback loop. Locate the wire that goes from the wiper of the feedback pot back to the main board. Send it through a switching (normally-closed) TRS jack that you put in place of the dry out jack. With nothing plugged into the feedback loop, the pedal works as normal. But when you plug a stereo "Y" cable in, you can add effects in the feedback loop so that each repeat gets more effect. Cool for dub-style.
These jacks have six terminals. Three are the normal tip, ring, and sleeve connections. The remaining three are switched contacts that are connected to the other pins when a jack is not inserted.
Jumper from the wiper to the tip connection to make the send, because it doesn't get shorted to ground if you plug a mono plug in. The tip connection should also have a jumper to the switched ring connection. The normal ring connection then goes to the wire that was originally connected to the wiper. This is your return. The sleeve gets connected to ground.
note: try to keep effects at unity gain to prevent overloading the mixing stage.
I've got a folder full of DD2 mods, but until now I've been too scared to do any. If I could make Baja's mods switchable (to retain oscillation) I'd go for it. It's a bloody tight fit in that enclosure though!
fish head
Post by fish head »
Does anyone know if this jack would work with the fx loop mod?
http://www.banzaieffects.com/Lumberg-ja ... 17601.html
JiM
Proco Rat
Hot Harmonics
Crackle Not OK
Has thanked: 69 times
Been thanked: 65 times
Post by JiM »
I guess these ones have all the switching you want :
http://www.banzaieffects.com/Jack-6-3-S ... 20099.html
http://www.banzaieffects.com/Taiwan-jac ... 18634.html
and they both are a bit cheaper.
But anything looking like that should work too : http://www.banzaieffects.com/Cliff-STE- ... 19694.html
fish head
Post by fish head »
cool, thanks a lot! :thumbsup
jonnyxjuturna
Post by jonnyxjuturna »
Hmmm, this could be fun. Has anyone besides the OP tried this? Does it sound nice?
arctumeda
Post by arctumeda »
Hi Guys,
Do you think the mod will succesed with the DD-6 ?
Regards,
Arctumeda
arctumeda
Post by arctumeda »
Anybody can Help Me ?
I've a new question : how can I can make the "High Frequency Delay" on the DD-6, because adding a capacitor to the plug of the Feedback pot doesn't work.
Arctumeda
I do not have the DD-6 schematic, so unfortunately I cannot help :(
arctumeda
Post by arctumeda »
yeah I know it because the DD-6 is a recent pedal.
Yesterday, i've test the "Bass Cut Mod" with solder a capacitor of 2n2 at plug 1 and 3 of the feedback know what does ... nothing !
Seriously, nobody has test any mod on the DD-6 ?
juni
Post by juni »
I presume these mods will work for a DSD-2 as well?
I have to open the sucker up and see how much the insides differ. The sound is not too great as it is, but still i'd probably like to have the "digital" sound behind a switch. And an fx-loop would be very nice also. Haven't found much use for the looping or triggering functions, it's too limited and lo-fi, so might just take that jack for it.
THE_SCORPION
Post by THE_SCORPION »
:hug: thank you BajaMan!!!
I've had a dd3-a since 96. These mods are absolutely stunning.
It's like Lee Perry possessed my pedal!
darscuzlo
Post by darscuzlo »
I did the cap mods to my dd-3a but not the resistors.
What to the new resistor values do?
claytushaywood
Post by claytushaywood »
Im a newb and am trying to figure out these mods for the dd3. I wanna have switchable hi cut using two different caps along with the original dd3 sound with a three position on off on switch. and Id like to do the fx loop mod but I cant quite figure out exactly how to do this. Can anyone help a newb with a more detailed description?
please and thank you
Your kindness will be rewarded!
ymmak
Post by ymmak »
Anyone knows whether this mod can be done to the Boss DD5? I have the schematic here.
ToneKarma
Post by ToneKarma »
bajaman wrote:Hello friends
These are mods I have done on several customers Boss DD2 or DD3 pedals to obtain a more realistic tape echo sounding device.
naturally - only a tape echo sounds like a tape echo :wink: , but these mods will certainly get you closer to a tape echo sound (without the noisy and inconvenient tape loops).
ps: check out that nice input buffer too. :wink:
Recently I got a non-working Mid-80s DD-2 for free :D .
Repaired it (only one broken cable and two broken pots) and immediately performed the Baja/FSB-DD2 mod.
Works like a charm and considering that it only contains four new parts it is amazing how much better it sounds afterwards !
Thanks Baja and happy New Year to you all !! :thumbsup
TK
