Overall, I'll have to say that I'm very impressed with the quality of construction. And no SMD!! It sounds good, too.
The stomp switch is board-mounted, but everything else is wired off-board. I'll need to desolder the leads to the 9v jack to fully remove it from the box (I'll be doing that later on this weekend and taking more photos).
There are five small trimmers mounted on the back of the PCB (the side facing when the enclosure lid is removed) labeled: "Balance", "Delay", "Bias", "Regen", and "Gain". For me, 300ms is just a tad too short, so I'm going to play around with the Delay trimmer and see if I can eek out some additional time without having it turn to mush.
The BBD and clock are Cool Audio reproductions (V3205 and V3102). Compander is NE570N. And there's also a TL072, which I assume is for buffering?
The only thing I thought was odd on this pedal is that the pots are PCB-mount but wired off-board. Maybe they had some leftovers from another project?
More pics to follow.
