Devi Ever Karaoke Party
- my favorite amplifier: deluxe reverb
- Completed builds: Zvex Fuzz Factory
Zvex Woolly Mammoth
Zvex SHO
Proco Rat with mods
Pulsar Tremolo
Ross Phaser with mods
Rebote Delay 2.5
Orange Squeezer
Krank Distortus Maximus
Marshall Speakersim
Fender Champ - Location: Gomel, Belarus
- Has thanked: 2 times
This is unverified scheme of the Devi Ever KP. Can somebody check it?
- IvIark
There you go, I'm sure someone will give it a try and let you know. I included a filter cap because there was a gap and I figured it was going to need all the help it could get:
- IvIark
It sounds like two from this description. Even though it only says Q2 it says that the 3M3 goes "from middle of Q1 to IN1":
>>> Karaoke Party
INPUT - IN1
GROUND - GND (either one)
9volt + - 9v (either one)
OUTPUT - OUT
3.3m resistor from middle of Q1 to IN1
R1 - jumper
R2 - 2.2M (red red green)
R3 - 10K (brown black orange)
C1 - .1uF (104)
C3 - .1uF (104)
Q2 - MPSA18 (same orientation as Q1 screen print)
- Greenmachine
- my favorite amplifier: Fender Blackface Deluxe Reverb
- Completed builds: Electra Distortion
Roger Mayer Octavia
Klon Centaur (Bajaman/Soulsonic)
DOD 440 Envelope Filter
MXR Phase 90
DOD FET Preamp
Dallas Arbiter Fuzz Face
Soulsonic Hunny Bunny Overdrive
BYOC Analog Delay
Craig Anderton Headphone Amp
Anderton Mini Amp
Bajaman Real Tube Overdrive
Fender Deluxe 5E3 with Tone Stack Mod.
Fender Princeton 5F2-a
Keen Neovibe
Aquapuss Delay
Anderton AMS-100 Guitar Synth (abandoned)
DOD 280 Compressor
Weird Sound Generator
Beavis Audio Noisy Cricket
80's Rat
ROG Thor
Big Muff
Green Ringer
Shin-Ei Fuzz
MXR Dynacomp
COT50
Really Cheap Compressor - Location: Jersey City, NJ
- Has thanked: 87 times
- Been thanked: 15 times
- Contact:
squrl wrote:IvIark wrote: I figured it was going to need all the help it could get
Zvex Woolly Mammoth
Zvex SHO
Proco Rat with mods
Pulsar Tremolo
Rebote Delay 2.5
Orange Squeezer
Marshall Speakersim
Thanks guys.
I made this scheme using the description on the website. You can see that it is very similar to Silver Crank (viewtopic.php?f=7&t=3704), but uses 3.3m resistor and Q2 is MPSA18 (from description).
I'm not sure about "3.3m resistor from middle of Q1 to IN1". If it's true, all should be ok.
- bajaman
- Has thanked: 568 times
- Been thanked: 2014 times
you have a dc bias path to the input
- I would add a 33n input coupling capacitor to avoid dc coupling to your guitar (and loud bypass switch pops
Zvex Woolly Mammoth
Zvex SHO
Proco Rat with mods
Pulsar Tremolo
Rebote Delay 2.5
Orange Squeezer
Marshall Speakersim
Ok, i'll try this when the parsel with transistors arrives from ebay
- teej212
im pretty sure it only has one transistor. see how the 33 directions say "Q1 - MPSA18
Q2 - 2N2907A"
the karaoke party only says Q2- she would have specified if there was another transistor in there i believe.
Q2 - 2N2907A"
Zvex Woolly Mammoth
Zvex SHO
Proco Rat with mods
Pulsar Tremolo
Rebote Delay 2.5
Orange Squeezer
Marshall Speakersim
In my mind it will be booster with only one transistor.
- mictester
Errr... No - I can see two transistors in that kit!teej212 wrote:no. the karaoke party only has one transistor.
this might help
http://www.etsy.com/listing/50620272/pu ... dark-boost
- HEAD
... just to mention it: Don't give a f*** for the "right" transistors. I tried several Devi "designs" with mostly BC type transistors. They all sounded the same - whether this ist good or not.
- celadine
There are multiple things you can build with the kit. The instructions are on the etsy page. Some only use one of the transistors. The Karaoke Party instructions are confusing, as they tell the builder to put the one transistor required in the place the second transistor would be.
Zvex Woolly Mammoth
Zvex SHO
Proco Rat with mods
Pulsar Tremolo
Rebote Delay 2.5
Orange Squeezer
Marshall Speakersim
I built this with two BC550C transistors. They have a lower hfe than mpsa18, so the sound was like a low-gain fuzzy drive.
Honestly i didn't hear the differense between variation with the 3,3M resistor and without it.
Also i replaced the bias resistor with 150K pot. This option can add some crackle to the sound.
this is what I came up with based on the descritions on her site and given that it's of a similar design to some of her other pedals....
Any comments are appreciated.
- Karaoke Party v1.png (27.63 KiB) Viewed 2688 times
