resistor to a pot
kin0
Post by kin0 »
Hay then I mod a pedal and put a pot instead of a resistor . Do I have to put lugs 2 and 3 in or 1 and 3 in the holes of the resistor. (I change two of them and in one I'll put resistor in parralel)
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
Depends what it's controlling mate; do you want the resistor to increase in value as you turn the knob up or decrease in value?
kin0
Post by kin0 »
At first pot I want to decrease the value as I turn the knob up and in the second pot to increase the value
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
That doesn't really help because we don't know what side of the resistor goes to what. So without seeing a schematic where we can advise which side of the resistor holes should wire to which side of the pot, you'll have to experiment with 1 and 2 linked to one side and 3 to the other, and if that's the wrong way then 2 and 3 linked to one side and 1 to the other.
kin0
Post by kin0 »
http://www.siz.co.il/codes.php?i=ng4koavzdw3n.gif
At pot number 1 I want to decrease the value as I turn the knob up and in the pot number 2 to increase the value.
If you can to help as fast as possible cause I am done with the mods until now and I'm excited to finish the wah today (only this two knobs left)
IvIark
Post by IvIark »
For pot 1 connect the transistor emitter to 1 and 2, lug 3 goes to ground. For pot 2 connect the 470K and 82K junction to 2 and 3, and connect the 10nF and 1K5 junction to 1.
