sn7274 and lm/ua741 - any uses?
- rocklander
- Has thanked: 1404 times
- Been thanked: 227 times
- Contact:
I was given a bag of half a dozen of each - metal can sn7274 and normal LM741/UA741.. any reason to or not to use the opamp 741's and what are the sn7274, and can I use them anywhere?
- Hides-His-Eyes
If they're in metal cans I'd just sell them; they're not that quiet and people think metal cans have Mojo...
- rocklander
- Contact:
I should have clarified, the 741 are just normal black.. it's the others that are metal can.. I can't even find what they are/do?
- theehman
It's a dual op-amp but I couldn't find any datasheets on it.rocklander wrote:I should have clarified, the 741 are just normal black.. it's the others that are metal can.. I can't even find what they are/do?
Ron Neely II
fx schematics and repairs
- rocklander
- Contact:
ah - k.. thanks for that.. but how did you know since the datasheets seem to be hiding ?
just seen them before?
- theehman
Googled it, found a few sites that mentioned it.rocklander wrote:ah - k.. thanks for that.. but how did you know since the datasheets seem to be hiding ?
Ron Neely II
- phatt
Hi Rocklander,
uA 741 is a single package Opamp (different pinout to dual)
sn7274 might be a dual opamp. A pic might help you discover more?
How many pins? what shape is it?
Phil.
Phil.
- the3secondrule
rocklander wrote: any reason to or not to use the opamp 741's
Build hotcakes with 'em!
"Rock music is mostly about moving big black boxes from one side of town to the other in the back of your car."
