Fulltone - Fulldrive 2 - Mosfet [traced]
- borislavgajic
- Opamp Operator
- Has thanked: 131 times
- Been thanked: 277 times
- borislavgajic
- Opamp Operator
- borislavgajic
- Opamp Operator
Thanks Peter.....
please can moderators erase last drawing....it is doubled by mistacke....
Boris
Boris
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
Is it possible for you to post a schematic for this Boris?.....
madbean
Here's a schem for reference, although I haven't checked Boris' layout to see if the correspond exactly.
- atreidesheir
I have built madbean's deadringer. It was so good I sold my fulltone custom shop fulldrive 2 (the cream one, almost my last boutique pedal).
This is my favorite TS. The boost is a bonus!
- atreidesheir
boris i like your layout style. Curves are great.
I also like your enclosure. Is it etched?
- borislavgajic
- Opamp Operator
....You are so kind....and yes it is etchedboris i like your layout style. Curves are great.
...thank you himister...so are you here to stey or you just dropped in by accident?...and I like those knobs! Where did you get them?
Great work as always bro!
.......Thanks...I have checked....differences are (errors on my build)......Here's a schem for reference, although I haven't checked
1...... resistor from base to V/2 of first transistor is 1M...should be 510k
2...... mosfet clipping section have no room for Ge diode( so cut trace and add it
3......most imprtant error is resistor 47K should not be connectedto pin 7 of the IC....so just pull it out from PCB and make wire connection to little SW
Boris
- borislavgajic
- Opamp Operator
Hi, folks. Does anyone have the correct schematic diagram of Fulldrive 2 mosfet pedal and you can send me on PM or e-mail?
Thanks a lot in advance!
- mysticwhiskey
I used this one: http://au.element14.com/multicomp/1md6t ... /155018501
Check the datasheet on that page for the pin configuration for each switch position.
Hay!
this looks nice! But i was wondering how does it sounds. has anybody compared it to the manufactured build????
I built one from aionelectronics.com/diy-pcb-projects/ (see his TS board) and i think it sounds pretty damn close to what I heard in the store with a real FD. I LOVE it!KRALJSIMON wrote:Hay!
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
