UK- 2 large enclosures for sale, binding posts wanted
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
Shouldn't have bought these, just too big. I could put multiple projects in each but I'd rather just sell.
Came from maplins so probably best deals would come from someone who factors postage cost into value ;) We'll see; open to trades as well. Looking for binding posts (round hole with hole and thumbscrew), BB and 145*95 enclosures, NPN Ges in FF ranges (would settle for PNPs and a charge pump :) ) 25v 220u caps (axial preferred but either) 47u caps in any voltage (2.5mm spacing preferred)... Or money to buy such things from Doc Tweek!
I have:
1 x 'LF14'/AB13 152*102*51mm 200g Sheet metal enclosure, long sides attached to lid, short sides to base (perfect for a sideways double pedal or for a vertical pedal with side jacks). Screws included.
1 x N93BQ die cast, probably eddystone but still in shrink wrap so can't check, 188x120x53mm, 520g 6 screw, you could really fit just about anything in this one...
Postage £2 for the sheet metal, £3 for the die cast or £3.50 for both.
Hope someone has use for these!
Scruffie
Has thanked: 28 times
Been thanked: 169 times
Post by Scruffie »
I'm interested in the N93BQ, just need to measure up my A/DA Board tommorow...
I have some PNPs and Charge Pumps... some Plastic Enclosures... and probably the Caps, i'll have a look tommorow, plus anything in this thread of course - viewtopic.php?f=17&t=10552
bencoles
Post by bencoles »
ill buy the enclosures off you. How much do you want?
Hides-His-Eyes
bencoles wrote:ill buy the enclosures off you. How much do you want?
I'll give you both posted for £14? And chuck in an insulated DC socket for each?
bencoles
Post by bencoles »
Call it a tenner? I don't have much use for them right now, but maybe soon! :thumbsup
