Tantalum restistors ...
- benobo
Hello to you,
Could someone let me know if i fit tantalum resistors, instead of classic metal ones, will really improve the sound? What difference it will make if i use 2Watts Res instead of 1/2 W ?
- earthtonesaudio
I think you mean flux capacitor.
- earthtonesaudio
Well I learned something new. I never knew tantalum resistors existed.
I can't tell you whether using tantalum resistors will do anything for the sound, but I can tell you that for a given material, higher wattage ratings generally result in lower noise. It's a tradeoff between physical size and low noise. For musical instrument amplification, particularly stompboxes, 1/4W metal film is hard to beat. In this cramped environment, going to a higher wattage does not decrease noise enough to warrant the larger size.
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
I tend to use 1/2 Watt Metal Film resistors alot in my pedal builds....
I couldn't buy any carbon composition resistors to use in my Fuzz Face,so I bought 1 watt carbon film types instead....
