Ibanez OD850 (first series)
Has thanked: 218 times
Been thanked: 857 times
Which one?
This one (thanks Discofreq):
More info:
http://www.effectsdatabase.com/model/ibanez/first/od850
Schematic:
Ibanez_OD850.pdf
(17.96 KiB) Downloaded 382 times
Copper layout: (let your printer do the resizing in the print menu (use Irfan View)!!)
Component placement:
Enjoy the build.
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Great work, many thanx for sharing that!!!
Do you know what kind of caps was used in the original? And which diodes for clipping?
roseblood11
Edit: Analogguru says that diodes are 1n4148:
http://analogguru.an.ohost.de/193/schem ... e_1974.gif
borislavgajic
Has thanked: 131 times
Been thanked: 277 times
Post by borislavgajic »
:cry: tears of happyness
Boris
Greg
Completed builds: LOTS..
Has thanked: 64 times
Been thanked: 163 times
Post by Greg »
I didn't know you guys were after this one.. there's been a schematic floating around the net for a long time..
Anyway, I have one in the cupboard, so any questions.. fire away.
A Big Muff derivative.
Nice work on the layout BTW Dirk.
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
Cool!!!....Thanks Dirk,I'll deffinitely have a go at building this one.... :)
I just had a look at the schematic,doesn't it look alot like the Big Muff Pi?.... :)
DrNomis wrote:Cool!!!....Thanks Dirk,I'll deffinitely have a go at building this one.... :)
Naturally. The OD850, this one as well as the later square button version, are big muff clones. Same for the Ibanez OD9 (not the later Maxon) as well as the SF5/FZ5 sixties fuzz. All Big muff clones.
rasta_maleek
Has thanked: 52 times
Been thanked: 52 times
Post by rasta_maleek »
thanks for sharing Dirk, i love transistor overdrives
Post by DrNomis »
So....Ibanez took the Big Muff pedal schematic,and put it into a pedal case the size of a TS808?....Hmmmm..... :)
I thought that the circuit was going to be derived from the TS series,I looked at the circuit board layout,fully expecting the IC in a prominent position,then I had to do a "double-take",then I thought to myself..."Eh?..what gives?",the pic you posted was the very first time I've ever seen one of those,Dirk... :)
Duckman
Has thanked: 320 times
Post by Duckman »
Kind of James tone section, but w/fixed bass... Add a bass pot can be easy, I guess
Greg
Post by Greg »
Dirk.. your schematic is quite different from the one that's been around for a while..
Did you trace it yourself ?
If need be, I can check mine, but it's not as simple as later Maxon/Ibanez boxes, as the circuit is mounted inside a plastic box which seems to be attached to the pots.. and obviously these are pretty valuable.
Greg_G wrote:Dirk.. your schematic is quite different from the one that's been around for a while..
Can you tell me one reason why to trust a fuzzcentral schematic ?
The fuzzcentral schematic is NOT from the first version - it is a stripped down version from the OD-850 with FET-switching.
Except some component values Dirk´s schematic is identical to mine - and I traced it myself (from guts).
Greg
Post by Greg »
analogguru wrote: Can you tell me one reason why to trust a fuzzcentral schematic ?
Cool.. thanks for clarifying analogguru.. I hadn't seen your schematic before.
When was the FET switching version built ?
Was it a wider case ?
roseblood11
It had the same enclosure, I think they only wanted to use a cheaper switch. I´ve read somewhere that it was build from 79 to 81:
Would be really great to have enclosures like that for diy projects!
roseblood11
... at the second view, I´m not sure if both enclosures are identical. Maybe the later one is the size of the original TS808?
Duckman
Post by Duckman »
roseblood11 wrote:Would be really great to have enclosures like that for diy projects!
I see some similar here, in the forum, but didn't remember where :oops: I'll be searching
Duckman
Post by Duckman »
Duckman wrote:I see some similar here, in the forum, but didn't remember where :oops: I'll be searching
After two hours... nothing :oops:
I think my memory is fooling me :lol:
mattpas
Post by mattpas »
I made both versions last year and really like V2. V1 is close to one of the many different Triangles out there ans V2 is closer to a Ram's Head
gilmour_pugliese
my favorite amplifier: DIY Hiwatt DR504
Post by gilmour_pugliese »
great work...
any chance to have a strip layout? :lol:
roseblood11
Search for a good layout for the Big Muff, use it as a starting point and draw your own layout ;-) Should be easy...
