Multi Clipper
I was in need of some kind of clipping testing ground, so I've made one. Not sure the DIP switch spacing, I hope it's fine.
BTW, I've made quite a few tagboard layout's but this is my first PCB. Be easy on my Mr.Dirk ;)
List shown in the file is just an suggestion - put there whatever you like to put
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
Nice one Pawel. I got a few of those DIP switches in a variety of poles from one of the Chinese eBay seller, and made myself up something similar on perf. Well worth having as a quick tester.
Thank you buddy. Can you measure the distance between the joints of DIP for me? I have no any, so I'm unsure about an accuracy of this layout
IvIark
Post by IvIark »
The pins are 2.5mm apart and top to bottom is 7.5mm (ish) so it will fit in standard vero or perf over 3 rows, 1 column per pole.
:thumbsup
So it should be fine :)
IvIark
Post by IvIark »
Yep, spot on :thumbsup
Has thanked: 98 times
Been thanked: 274 times
Post by DrNomis »
Cool idea,sort of reminds me of the Bixonic Expandora.... :)
Another way to do this would be to use a multi-position rotary switch to switch in the different types of clipping.... :)
DrNomis wrote:Cool idea,sort of reminds me of the Bixonic Expandora.... :)
Yep, I was thinking to use it with rotary switch at first but that can limit it to try one set of diodes at one time. On off SPDT'a are also the way to go
Pawel
Has thanked: 218 times
Been thanked: 857 times
sinner wrote:Be easy on my Mr.Dirk ;)
:mrgreen: No probs here, the idea is nice for quick listening.
Bear in mind though that sonic differences between diodes can be a lot less if you compensate the gain. For instance, when you switch between a LED and a 1N400x sonic differences are audible because of the higher forward voltage of a LED. When you compensate that added level the sonic differences are suddenly very little.
Other than that parallelling diodes is not going to work. But you since you do'nt mention that you knew that already. ;)
No I didn't, so to be sure - I can not stack couple, or few diode sections?
You can....physically. :blackeye
But the diode with the lowest forward voltage drop will do all the work and since the voltage will never rise above that voltage.. the others will not have any influence...ever. :secret:
lolbou
Has thanked: 305 times
Been thanked: 220 times
Post by lolbou »
Any more clues about the voltage compensation while you're at it? What's the trick to achieve it?
- Are you a mod or a rocker?
- Uh, no, I'm a mocker.
Dirk_Hendrik wrote:You can....physically. :blackeye
Thanks for explanation :hug:
It forced me to redo it. It's super tight, I hope I'll be able to squeeze all the components I wanted to have
Final version with smooth out mica cap added
roseblood11
Has thanked: 359 times
Been thanked: 312 times
Post by roseblood11 »
Nice!
I found a similar layout on my hard disk. I don´t know who drew it...
This is what's inspired me. But sins I didn't know who draw it (unable to give a credit) I couldn't put it on my website, I've done my own. I like the possibilities of mine better, but the layout of HIS flexiclipper is smarter! I'll be better in time :oops:
