Wampler - Faux Tape Echo
Jack Deville
Completed builds: too many. too many.
Been thanked: 86 times
Post by Jack Deville »
indyguitarist wrote:much, much simpler than what most of you are probably assuming... Jack knows I believe :)
You are right, but its your pedal. I ain't spillin no beanz. :secret:
I'm a "professional."
Buy my products and make me rich.
www.jackdeville.com
rasta_maleek
Has thanked: 52 times
Been thanked: 52 times
Post by rasta_maleek »
i like soo much this pcb, looking for advances in this proyect.
Brian, Your a genius! i love your pedal´s tone
Sweetalk
Has thanked: 22 times
Post by Sweetalk »
Anyone has traced this?, I just curious about the PT2399 filtering stage (pre and post).
okgb
Has thanked: 222 times
Been thanked: 38 times
Post by okgb »
The vactrols are most often [ as i've seen ] used in compressor circuits ,
the led may be like a " half wave rectifier " ? set up with some kinda threshold to just mess
with the signal [ level wise ] a little to make it sound inconsistently inconsistent .
[ but only on the tape side ]
Gotta do something to market it and make it stand out , if a stock circuit .
indyguitarist
Been thanked: 161 times
Post by indyguitarist »
okgb wrote:The vactrols are most often [ as i've seen ] used in compressor circuits ,
nope, way off. It's used in the modulation.
grrrunge
Completed builds: Loads!
Has thanked: 50 times
Been thanked: 203 times
Post by grrrunge »
I'm guessing the LDR side of the vactrol is in series with the delay time pot. Just my n00b'ish 2 cents :)
Sweetalk
Post by Sweetalk »
My guess is that the opto + LED are set as clippers of a half of one of the Opamps but no audio passing there. The resistive part of the opto is affecting the delay pot (in series can be an option) and the modulation pot is in paralel to the opto to set the max R so the max time difference with the LED on / off.
aegert
Has thanked: 39 times
Been thanked: 56 times
Post by aegert »
F@#$ it all! I ordered one... I was going to grab a Strymon El Capistan but $"s Damn! How many Delays does one man need!??!?! So now do I have to buy the TC Alter Ego!?!?!?!? Someone talk me down.... Breath.... :roll:
aegert
Post by aegert »
Mine just came... Warm lush repeats.. love this thing! Great pedal.. Thanks Brian great great job!
Adam
mrkaploca
Has thanked: 15 times
Been thanked: 12 times
Post by mrkaploca »
downside gut shots? trace? :)
aegert
Post by aegert »
mrkaploca wrote:downside gut shots? trace? :)
I thought that was all done. Is the consensus you all need more shots to wrap this u? if so I will ripp thuis apart after band practice on Sunday... Let me know. I thought that was done..
A
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
I believe that the modulation wasn't traced. I also think there is enough information in this thread to make it work. ;)
But there are those that will want an exact, complete schematic. And we don't have that yet.
aegert
Post by aegert »
I bought it to support Brian... I thought that there were not more detailed shots for the same reason. i don't want to hurt him He has been such a supporter of the forums.. If it is the consensus that we need more shots I can help if we want to leave it as is with info as is I will salute that.. Lets have a collective yea or nay here..
A :D
briggs
Has thanked: 27 times
Been thanked: 126 times
Post by briggs »
Listening to the demos it just sounds like an envelope follower driving the vactrol which is either 1) over the delay pot (don't think it's this one) or 2) over a small resistor, maybe 3k3 to 10k (like a depth control) that is switched in series with the delay control.
I am Klon.
mrkaploca
Post by mrkaploca »
I'd say it's side chain opamp with led to rectify and get the envelope follower to drive transistor switch with vactrol across delay pot...
HHR18
Has thanked: 18 times
Post by HHR18 »
Any updates on this, would love to build it since it just sold my Boss Space Echo!
atreidesheir
Has thanked: 441 times
Been thanked: 43 times
Post by atreidesheir »
Jack deville is such a tease with his "bomb-maker's attention to detail."
Jack Deville
atreidesheir wrote:Jack deville is such a tease with his "bomb-maker's attention to detail."
:lol:
:scratch:
:hug:
www.jackdeville.com
Hurrah! Freestompboxes.org died when people think that tracing a circuit will damage the builders... or is in some way contrary to the law. What every traced unit the last five years has shown, is that every unit takes its inspiration somewhere. Yet if this is an interesting pedal, people should be curious to know how its done.
It's done by simply tracing the unit. No by sucking the builders cock until he reveals a secret. Sure professional builders can partipate in discussion, but they should sign up anonymously. If they respect the totally non-commercial orientation of the board, that is....
aegert wrote:I bought it to support Brian... I thought that there were not more detailed shots for the same reason. i don't want to hurt him He has been such a supporter of the forums.. If it is the consensus that we need more shots I can help if we want to leave it as is with info as is I will salute that.. Lets have a collective yea or nay here..
A :D
culturejam wrote:I believe that the modulation wasn't traced. I also think there is enough information in this thread to make it work. ;)
Jack Deville
modman wrote:Hurrah! Freestompboxes.org died when people think that tracing a circuit will damage the builders... or is in some way contrary to the law. What every traced unit the last five years has shown, is that every unit takes its inspiration somewhere. Yet if this is an interesting pedal, people should be curious to know how its done.
So...
Should I change my name?
Stop posting?
Leave the board?
Just tryin to do right.
:thumbsup
www.jackdeville.com
