Dirk Hendrik - Real Tube Screamer (1590bb) [documentation]
Great project.I will start to make one .I have a spare 12ax tube.Does anyone have the parts listed?
indeed i need a 12au7 but by mistake i bought the ax so i look for a tube circuit for this tube.
- Dirk_Hendrik
roseblood11 wrote:It should work much better at 12V than the 12AX7.
why?
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
Dirk, I was wondering if you are selling PCBs for this project because, after building Bajaman's Real Tube Overdrive, I would like to build one of these for myself, but at the moment, I don't have any etchant to etch myself a PCB, I've got plenty of PCB material though, otherwise I'd etch myself a board, any help would be much appreciated....
- DrNomis
dromilious wrote:indeed i need a 12au7 but by mistake i bought the ax so i look for a tube circuit for this tube.
You should be able to use any tube in this project, provided that it is pin-for-pin compatible, 12AU7, 12AT7, and 12AX7 should all work fine, you'll just get different levels of tube gain....
- grrrunge
Sweet build!Dirk_Hendrik wrote:
and
- DahakaNishoba
+1DrNomis wrote:Dirk, I was wondering if you are selling PCBs for this project because, after building Bajaman's Real Tube Overdrive, I would like to build one of these for myself, but at the moment, I don't have any etchant to etch myself a PCB, I've got plenty of PCB material though, otherwise I'd etch myself a board, any help would be much appreciated....
if you are selling the pcb for a reasonable price i'm up for one...
I still cant etch myself boards...
The way electronics work in a stompbox is like the way pixels move in a videogame
it's Magic, in Technology
- Dirk_Hendrik
It's mounted in the base of the tube socket.gefi wrote:Hello
in the schematic there are two LEDs, which fulfills the function that is mounted on the pcb of the valve?, here I do not see
Greetings
No probe etching a few but I'd be more happy if I could do 5 or more at the same time.
Would 25 euro's including drilling, cutting to suze and fluxing the thing be OK?
preps better followup throuhh PM.
- DrNomis
Dirk_Hendrik wrote:It's mounted in the base of the tube socket.gefi wrote:Hello
Greetings
Would 25 euro's including drilling, cutting to size and fluxing the thing be OK?
preps better followup through PM.
Yeah, 25 Euros sounds fine to me, I'd have to convert that to Australian Dollars though, do you accept payments via Paypal Dirk?....
Hmmmm...maybe a few other members would be interested in getting some PCBs for this project....
- grrrunge
I might like a board as well.. Could you upload some audio clips, so i can decide if i like the sound of it or not?Dirk_Hendrik wrote:It's mounted in the base of the tube socket.gefi wrote:Hello
Greetings
- grrrunge
Is this it: ?
If so, I'd like to have one as well
- DrNomis
grrrunge wrote:Is this it: ?
I reckon it is, since the way all the controls, the led, and footswitch are laid out, looks similar to how Dirk has laid things out....
Quite a nice sounding pedal, good Blues tone....
- Dirk_Hendrik
Ntot sure.DrNomis wrote:I reckon it is, since the way all the controls, the led, and footswitch are laid out, looks similar to how Dirk has laid things out....![]()
The layout is right.. but mirrored.
And the DC jack is relocated....
- DrNomis
Dirk_Hendrik wrote:Ntot sure.DrNomis wrote:I reckon it is, since the way all the controls, the led, and footswitch are laid out, looks similar to how Dirk has laid things out....![]()
Or, it could even be that the video is flipped horizontally...
sorry the power is 12 dc or Ac?i have seen many schematics which say 12 ac.if here we have dc where is the difference?
- Dirk_Hendrik
- DrNomis
I just found myself a couple of JRC4558S ICs which I could use to build a vero layout version of this project, the JRC4558S is the Single Inline version of the JRC4558, I believe...
