HAO - Rumble MOD
- jakerandall
kusi any chance of a rust booster.
- modman
- a d m i n
- Has thanked: 4287 times
- Been thanked: 2008 times
No chance at all: all hard work (not by me though)jakerandall wrote:k**i any chance of a rust booster.
HAO Rust Driver gut shots - schematic - manual PDF - pcb layouts
- analogguru
Here some guts:
http://www.digimart.net/images/64/DS00319588_1.jpg
http://www.digimart.net/images/64/DS00319588_3.jpg
Hi, I was wondering if the numbering of the pots correct?
Also if they are correct should the 2nd lug of the dual pot stay open?
I built this without paying attention to the numberings(thought it was the 1-3 left to right) and resulted with no sound.
- Pedalpusher
One of these days I'm going to build an "improved" version of this pedal. The colour knob has a spot where it sounds good with single coils and another where it sound good with hums. I'd just use a switch to with 2 fixed resistances and label it Hum/Single, then figure out where to put a more useful tone control. Maybe even a bass and treble control.
- idy
- Completed builds: FFs, Octavias, TBMKIIIs, Buzzarounds/alikes, Axis Fuzz', CS Overdriver, BMPs, Black '65s, MOSFETODs, WiiO, RAH, Klons, AC30, DLS, TSs and many variants, Small Clones, UniVibes, E. Mistress, Mutron Env Filter, Ross/Dynacomps,, EA Trems, TremLunes, Katana Boosters, BYOC Tri Boosters, other boosters and buffers, PT2399 delays, SKRM based delays, Belton Brick Reverbs, 3band parametric EQ,
- Has thanked: 27 times
- Been thanked: 31 times
Opened up one of these. The schematic above doesn't quite get the dual pot/boost-drive thing. The toggle switches between the two halves of the dual pot, one of which has a low limit resistor and the pair of diodes. Why they bothered with the dual pot I miss/ escapes me.
