Having Trouble Locating Some Components
camsna
Post by camsna »
I'm starting a few projects and am having the darndest time finding the following things. Can someone please turn me in the right direction?
Thanks so much!
(By the by, I've already looked at Small Bear, PPP, and Effects Connection)
Resistors:
680 K
422 K
392 K
Caps:
.03uf
.015uf
.39uf
.027uf
.0039uf
Diodes:
1n60
BAT41
1N4004
500 K trimmer
ICL7660SCPA
Thanks so much! Can't wait to get started!
Cam
Hides-His-Eyes
Has thanked: 50 times
Been thanked: 49 times
Post by Hides-His-Eyes »
Resistors now only come in standardised values; you'll need to pick the closest one depending on the tolerance of the resistors you're buying (eg carbon film resistors are +-5%; what would be the point of them making both 390k and 392k when the 390k could easily have MORE resistance than the 'bigger' resistor!)
That said, you are I'm afraid clearly looking wrong, because 680k is a standard value, and 500k trimmers are perfectly common :)
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
I'm pretty sure Futurlec has all the items. The .03uF cap will be 33nF (or 0.033uF) but apart from that I expect all the rest should be easy to find except their ICL7660 isn't the S version, so you'd probably need to go for a MAX1044CPA.
