Where to buy pots with solder lugs in Australia?
- DrNomis
- Has thanked: 98 times
- Been thanked: 274 times
dusura wrote:Hi,
anyone know of good place in Australia with a decent range of pots with solder lugs . All I can seem to find are PCB mount.
I'm looking for B100K dual gang amongst others.
Thanks in advance,
Dave
You could try Altronics,Jaycar Electronics have a range of 24mm and 16mm Alpha pots which I tend to use alot in my pedal builds,they are PCB mount,but I found that you can still solder wires to their lugs,each lug has a thin section that normaly fits into a hole in a PCB,to solder wires to them,I sharply bend the thin section up at 90 degrees,facing in the opposite direction to the shaft,then I use a pair of needle-nose pliers to make a small loop in the tinned end of a piece of wire,just large enough to fit on the lug,then I solder it in place....works for me.....
- DrNomis
dusura wrote:Yeah, I have been getting my pots mainly from Jaycar but they are all PCB mount. I like your method for connecting wires to PCB mount though. I might give that a go. It sounds like it makes a pretty durable connection.
Yeah,the connections are pretty durable,the only time I have ever had a pot fail on me was when I overheated the solder lug while soldering a wire to it,for some strange reason,I found that certain values of pots tend to be more prone to it than others,but it doesn't happen very often for me though....
- jbgron
I've given up with local electronics stores guys, they never have stock and are 4x the price of overseas suppliers. I get all my stuff from Futurlec, Tayda and Small Bear these days.
