Where to find external nut 9v jacks?
D-Day
Mojo Book Buster
my favorite amplifier: Soldano SLO 100
Completed builds: Bazzfuss, Fuzz Face, Fuzzface SG
Has thanked: 107 times
Been thanked: 23 times
Post by D-Day »
Off topic: Would someone be so kind as to point me in the direction of the AC adapter jack used in the pedal above? These internal nut ones I've been using are starting to annoy me...
Thanks in advance!
culturejam
Has thanked: 432 times
Been thanked: 562 times
Post by culturejam »
D-Day wrote:Off topic: Would someone be so kind as to point me in the direction of the AC adapter jack used in the pedal above? These internal nut ones I've been using are starting to annoy me...
Smallbear has the external metal nut jacks.
Has thanked: 218 times
Been thanked: 857 times
Thanks in advance!
For me it's the other way around. These ugly sticking out of the case jacks annoy me far more.
theehman
Has thanked: 97 times
Been thanked: 102 times
Post by theehman »
Thanks in advance!
+1
Ron Neely II
fx schematics and repairs
D-Day
Mojo Book Buster
Post by D-Day »
Thanks guys!
I like the idea of removing all of the guts with no desoldering or cutting leads. I've also had the pleasure(?) of doing a couple of really claustrophobic builds and I like how little space it looks like the exterior nut type takes up.
I'm sure I'll be using both types in the future.
IvIark
Has thanked: 561 times
Been thanked: 586 times
Post by IvIark »
D-Day wrote:I like the idea of removing all of the guts with no desoldering or cutting leads.
I agree, and they're especially nice in 1590A builds to give you a bit more space in the box. I've got both types but these definitely have their place. I bought some from Partspipe on eBay, but I've just noticed this seller doing them a bit cheaper. They look exactly the same ones to me.
D-Day
Mojo Book Buster
Post by D-Day »
Rad! Thanks IvI!
But now I feel bad because this is a thread about a sweet pedal but mainly all that's been talked about are AC jacks :(
MoonWatcher
Has thanked: 40 times
Been thanked: 52 times
Post by MoonWatcher »
You might also want to consider trying the type used in Boss pedals and the like - you can just slide everything out without even having to deal with the nut at all!
A Dremel, some files, and a notching tool will make the cutout in just a little more time than it takes to drill the .5"/13mm hole for the barrel jack.
The other nice thing about that jack style is that you can get it way up in the corner of your enclosure, since you don't have to mess with the nut.
Steven_M
Has thanked: 59 times
Been thanked: 35 times
Post by Steven_M »
I get these from Jameco.
http://www.jameco.com/webapp/wcs/stores ... llDownView
$0.79 each if you buy ten. I also like these because it allows me to solder into a mock enclosure so I don't wreck whatever finish I have on the real enclosure. Also gives more room inside. I find they do stick out a little too far for my taste, but the ugly white nylon washer that accompanies the 3PDT switches fits on these perfectly, which puts them back inside the enclosure enough to warrant me buying them.
rocklander
Has thanked: 1404 times
Been thanked: 227 times
Post by rocklander »
for the same reason (ability to remove insides without desoldering) I bought some too.. not for all builds, more for the ones I make for someone else who wants to paint it themselves.
got mine from effectsconnection
single, http://www.effectsconnection.com/oscomm ... cts_id=349
10x http://www.effectsconnection.com/oscomm ... cts_id=151
100x http://www.effectsconnection.com/oscomm ... cts_id=652
D-Day
Mojo Book Buster
Post by D-Day »
Better and better! Thanks guys!
And a kind thank you to whichever mod moved this from derailing the Wampler Nirvana Chorus thread :thumbsup
